Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > Ohio Radio Discussion Forum
Ohio Radio Discussion Forum Forum for discussing Radio Information in the State of Ohio.
  #881 (permalink)
Old 02-07-2013, 1:53 PM
mtindor's Avatar
OH/WV DB Admin
Send a message via MSN to mtindor
Originally Posted by fpo701 View Post
More traffic on 2-018 site today. One location was Main and Peachtree, also Strauser and Wales. Both are in North Canton area. They were also in Wilmot and Dalton.
At this point, I could just be getting two guys talking from two different locations and a third local to 2-018. This site shows a very strong signal in Akron, so I assume it is near me.
I'm quite sure that the majority of those unknown 2-xxx sites are in NE Ohio. Stark / Summit / Mahoning / Lorain / Ashtabula / etc.
We need people to start scanning 700 Mhz and reporting on all of the sites that they find. I'm sure there are more out there that nobody knows about simply because you, I and Tom can't pick them up direct from our locations. The NE digital scanner enthusiasts need to jump on board and pull out their digital scanners and Pro96Com and start looking for active 700 mhz control channels and reporting on them [along with the location they were monitored from].
Mike Tindor, AA8IA
Ohio/WV DB Admin
PSR500/PSR800/PRO197
www.aa8ia.org
Jefferson Co, OH Scanner Feed
  #882 (permalink)
Old 02-07-2013, 10:06 PM
Schmetzy13's Avatar
I am in Mahoning county (Canfield) and am able to pick up site 2-019 with one bar of signal. Screen reads 0348h-0219.
I have not hit any TGIDs as of yet on my BCD-396xt, but have been searching the 700 band periodically.
Send a 55...
  #883 (permalink)
Old 02-08-2013, 8:29 AM
mtindor's Avatar
OH/WV DB Admin
I'm guessing that the control channel frequency for Site 0219 is the only 700 mhz control channel you can pick up from your location, is that correct? It helps to know that. I'm also presuming you are using either the stock ducky antenna or an 800 mhz ducky antenna [vs an external antenna] ?
I'd ask you to consider running Pro96com on that site [and I'd walk you through getting it set up], but I have a feeling that one bar is not adequate enough signal to get a reliable decode of control channel data in Pro96Com.
My guess so far is that 2-019 might actually be the Ohio State Penetentiary or Trumbull Correctional MARCS-IP site. Perhaps even Salem, but I believe I'd hear it from here in Jefferson Co if it were Salem.
How close would you say you are to Ohio State Pen and Trumbull Correctional?
Mike Tindor, AA8IA
Ohio/WV DB Admin
www.aa8ia.org
  #884 (permalink)
Old 02-08-2013, 12:48 PM
Schmetzy13's Avatar
Correct, this is the only control channel I can pick up from my location with my stock duck antenna.
I downloaded Pro96com, adjusted the settings and could not receive any data. I even tried with the Austintown P25 system to see if I could gather anything and I couldn't with 5 bars... Any suggestions as to settings?
As for OSP and TCI, I am about 20 miles from there.
Send a 55...
  #885 (permalink)
Old 02-08-2013, 1:24 PM
mtindor's Avatar
OH/WV DB Admin
I'll respond via private message since I'm going to go off topic and try to help you get Pro96Com working.
Mike Tindor, AA8IA
Ohio/WV DB Admin
www.aa8ia.org
  #886 (permalink)
Old 02-10-2013, 12:25 AM
Default Geauga County
I'm hearing the Geauga Co. Sheriff Dept for the first time on this system 1:00 AM Sunday. Very clear from the east side of Cleveland using a HP-1. I heard some of the Geauga schools all week but nothing PD or FD. Switch over maybe??
  #887 (permalink)
Old 02-10-2013, 8:51 AM
Been hearing TGID 19504 Geauga Co SO since Friday.
  #888 (permalink)
Old 02-10-2013, 9:10 AM
Also FD TGID 19525 logged but not heard.
  #889 (permalink)
Old 02-10-2013, 9:31 AM
KWs's Avatar
KWs KWs is offline
I'm hearing 19504 also .. Have not heard any FD traffic ..
KWs
  #890 (permalink)
Old 02-10-2013, 1:05 PM
KWs's Avatar
KWs KWs is offline
I'm receiving Geauga Sheriff 19504 off the Cuyahoga tower sites,
all the unit IDs display as 2800370 ... Some sort of patch ? Or ???
I'm not getting the traffic off a Geauga tower.. Seem to have issues with reception.. Time for an attic antenna adjustment !
KWs
  #891 (permalink)
Old 02-10-2013, 1:20 PM
The majorty of my reception is off the Beechwood site but I do see some off of a Geauga site. 855.2125 is very strong. 0348h-0210.
  #892 (permalink)
Old 02-10-2013, 1:39 PM
KWs's Avatar
KWs KWs is offline
And upon further review, seems unit ID display holds up a lot longer on this system than others I monitor, so it seems like the next unit talking is not displaying their ID on my HP .. at least from my location.
KWs
  #893 (permalink)
Old 02-10-2013, 6:04 PM
I live 1 mile from TCI and have a full scale signal on 773.0812 with a rubber duck. Site ID is 0348h-0221.
  #894 (permalink)
Old 02-10-2013, 9:45 PM
wa8pyr's Avatar
Technischer Guru
Take the antenna off the radio and see if you can still hear the control channel. If so, that's likely the TCI site.
Tom Swisher, WA8PYR
RR Admin/Moderator
PSR500/Pro197/Pro2035+OS535
www.wa8pyr.info
  #895 (permalink)
Old 02-11-2013, 3:56 PM
I get 2 bars with the rubber duck off.
  #896 (permalink)
Old 02-11-2013, 9:15 PM
wa8pyr's Avatar
Technischer Guru
OK, that pretty much nails that one. I'd say TCI. Please submit to the database if you haven't already.
And just to clarify, you are talking about Trumbull Correctional, correct?
Tom Swisher, WA8PYR
RR Admin/Moderator
www.wa8pyr.info
  #897 (permalink)
Old 02-12-2013, 4:52 PM
I did not submit it.
Yes it is the state prison.
  #898 (permalink)
Old 02-18-2013, 3:52 PM
KWs's Avatar
KWs KWs is offline
Not hearing much, if anything, on Geauga system lately ... how about anyone else ?
For whatever reason my reception drops out at times, as indicated by the HP-1 system analyzer.
On the other hand, I plugged in the new P25 Portage / Shalersville CC .. that comes in very strong. I get Solon and Chagrin PD off this tower (but not Fire ?? ) , even though I also get them off the Cuyhaoga system just fine. I'm hoping maybe Geauga will affiliate with the Portage tower in future ...
KWs
  #899 (permalink)
Old 02-18-2013, 4:05 PM
mtindor's Avatar
OH/WV DB Admin
Hi,
Since you have the system analyzer, could you tune to the Shalersville site and obtain the active frequencies in use, primary / alt control channel, and any site neighbors?
If you're willing to do that, you can post the info here, PM it to me, or submit it to the RRDB. Whatever you prefer.
Thank you,
Mike Tindor, AA8IA
Ohio/WV DB Admin
www.aa8ia.org
  #900 (permalink)
Old 02-18-2013, 4:29 PM
KWs's Avatar
KWs KWs is offline
So far I see ..
CC as 773.5812, that is already posted.
Voice freqs of 771.0062, 771.3812
I'll keep checking.
KWs
Tags
700 mhz, central ohio, clark county, dayton, elyria, fayette county, london, lorain county, marcs, marcs p25, marcs-ip, ohio, ohio marcs cuyahoga, southwest ohio, springfield, urbana, washington ch
