Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > Ohio Radio Discussion Forum
Ohio Radio Discussion Forum - Forum for discussing Radio Information in the State of Ohio.
  #1281 (permalink)
Old 10-10-2013, 2:27 PM
mtindor's Avatar
OH/WV DB Admin
Originally Posted by sopranosno1 View Post
catching two new sites for marcs ip, 774.30625 site-22 and 774.58125 site-23.
From what location? Ohio is a big state.
Mike / AA8IA
PSR800/PRO197/BCD436HP/BCD536HP
  #1282 (permalink)
Old 10-10-2013, 3:14 PM
wa8pyr's Avatar
Technischer Guru
He is out toward Dayton so somewhere in that neck of the woods. They're not peers to Columbus or Circleville, and not audible from Columbus, either.
Tom Swisher, WA8PYR
Lead Database Administrator
PSR500/Pro197/Pro2035+OS535
www.wa8pyr.info
  #1283 (permalink)
Old 10-10-2013, 3:30 PM
mtindor's Avatar
OH/WV DB Admin
Rgr. Thanks, Chief Maybe New Madison or West Alexandria then.
M
  #1284 (permalink)
Old 10-10-2013, 3:35 PM
mtindor's Avatar
OH/WV DB Admin
Do you have the capability or hooking your scanner to a computer and running Pro96Com or Unitrunker to obtain full site details [including site neighors]?
Mike / AA8IA
  #1285 (permalink)
Old 10-10-2013, 4:53 PM
I understand that the Ohio State Highway Patrol is on MARCS. What other agencies in Southwestern Ohio are also on it? Thanks.
  #1286 (permalink)
Old 10-10-2013, 4:57 PM
mtindor's Avatar
OH/WV DB Admin
Hi,
This thread is about MARCS-IP. Your question appears to be about MARCS. If you want to know who is using MARCS, just check out the DB.
Ohio MARCS - Multi-Agency Radio Communications Trunking System, Statewide, Ohio - Scanner Frequencies
Mike / AA8IA
  #1287 (permalink)
Old 10-10-2013, 7:47 PM
mdulrich's Avatar
I am picking both of these sites up in Lima off a Uniden 396XT with an 800 MHz antenna with the 774.30625 coming in stronger.
This is what Unitrunker is showing:
Site 001-022 (WPTZ770) CC 774.30625 AC 769.35625 Neighbors are 001-018, 001-023, and 002-028 (Lima)
Site 001-023 CC 774.58120 AC 772.98125 Neighbors are 001-015 (Troy), 001-022, 001-028 (Greenville), and 002-028 (Lima)
Streaming the Allen County, Ohio Public Safety Scanner at http://www.broadcastify.com/listen/feed/188
Providing ADS-B data from NW Ohio for http://www.flightradar24.com
  #1288 (permalink)
Old 10-10-2013, 8:20 PM
mtindor's Avatar
OH/WV DB Admin
Thanks, Mike. I'll digest an add it to the DB.
Mike / AA8IA
  #1289 (permalink)
Old 10-10-2013, 8:32 PM
mtindor's Avatar
OH/WV DB Admin
Mike,
We don't have 001-018 in the DB. Can you try and get the frequency of that peer off of 1-022 ?
Mike / AA8IA
  #1290 (permalink)
Old 10-10-2013, 8:40 PM
mtindor's Avatar
OH/WV DB Admin
Mike,
Based upon that info I think 1-022 is Wapak and 1-023 is Celina. I have added them to the DB that way. The Alt CC of each site is on an existing license for each site.
If you can get the CC for 1-018 (peer of 1-022), that'd be great.
Mike / AA8IA
  #1291 (permalink)
Old 10-10-2013, 9:07 PM
mdulrich's Avatar
Mike,
Based on signal strengths, I would concur with your assumptions on the locations.
1-018 is CC 773.15625
Also both sites are now showing a peer of 1-019 with a CC of 774.53125 I'm unable to receive that CC.
  #1292 (permalink)
Old 10-10-2013, 9:25 PM
mtindor's Avatar
OH/WV DB Admin
WQRI426 (OHIO, STATE OF) FCC Callsign Details shows 773.15625 as a freq. This the Bellefontaine license. And that would make sense [in my mind] since Bellfontaine (if 1-018) is a direct neighbor (distancewise) of Wapak but not Celina. And you said that the Wapak site did indeed list 1-018 as a neighbor.
For now, I'd say that we should imagine 1-018 to be Bellefontaine. Let's face it -- it's a guessing game most of the time since the primary CC [and in some cases the alt CC] are often using freqs from the blanket license.
Mike / AA8IA
  #1293 (permalink)
Old 10-10-2013, 9:38 PM
mtindor's Avatar
OH/WV DB Admin
I'm betting that 1-019 is Fort Recovery, Osgood (North Star), or Sidney.
mike
Mike / AA8IA
  #1294 (permalink)
Old 10-10-2013, 9:41 PM
mtindor's Avatar
OH/WV DB Admin
Mike,
Lima was originally reported to have the following neighbors:
1-008, 1-026, 1-028, 2-012, 2-031, 2-035
Can you check Lima when you get a chance and see if any of those neighbors changed?
  #1295 (permalink)
Old 10-10-2013, 9:49 PM
wa8pyr's Avatar
Technischer Guru
Neither 18 or 19 is audible or shows as a neighbor in the Columbus area (including Riverview).
Tom Swisher, WA8PYR
www.wa8pyr.info
  #1296 (permalink)
Old 10-10-2013, 10:09 PM
mdulrich's Avatar
Lima is showing peers of 1-008 (Urbana), 1-015 (Troy), 1-022 (Wapakoneta), 1-023 (Celina), 1-026 (Marysville), 1-028 (Greenville), 2-012 (Marion), 2-031 (Findlay), and 2-035 (Paulding)
  #1297 (permalink)
Old 10-10-2013, 10:29 PM
mtindor's Avatar
OH/WV DB Admin
Thanks. I updated the neighbor listing for Lima. It'll be interesting to see if 1-018 pans out to be Bellefontaine in the end.
Mike / AA8IA
  #1298 (permalink)
Old 10-10-2013, 10:35 PM
sopranosno1's Avatar
Thumbs up
this weekend we will drive around mercer auglaize logan and see if we can narrow these down. get half way close to a tower then unplug the antenna from the scanner see if the signal is still present. dont have unitrunker, im in sidney right under auglaize and mercer and southwest of bellefontaine.
  #1299 (permalink)
Old 10-10-2013, 10:45 PM
mdulrich's Avatar
From your location can you hear 773.15625 or 774.53125?
  #1300 (permalink)
Old 10-11-2013, 1:48 AM
Thunderbolt's Avatar
Forums Moderator
I see the Bradner site (02-14) has added more frequency pairs:
FileVersion:7
-TowerInfo
#This section is here for information only. With the exception
#of the Call Sign(s), This data is not Read back into the program at all.
System ID : 348
System Name : Ohio MARCS
WACN : BEE00
Tower Number (Decimal): 2-14
Tower Number (Hex) : T020E
Tower Description : Bradner
Control Capabilities : Data,Voice,Registration
Call Sign(s) : WPTZ770
Timestamp : Fri Oct 11 01:44:21 2013
-Tables
#Format: Table ID,Base Freq,Spacing,Input Offset,Assumed/Confirmed,BandWidth,Slots
00,851.00625,0.00625,-45.00000,"Confirmed",0.00625,1
01,762.00625,0.00625,30.00000,"Confirmed",0.00625, 1
02,851.01250,0.01250,-45.00000,"Confirmed",0.01250,2
03,762.00625,0.01250,30.00000,"Confirmed",0.01250, 2
-Frequencies
#Format: Channel,Usage,Frequency(/Slot),Input Channel,Input Frequency(/Slot),Input Explicit(1/0),Hit Count
"01-1184","i",769.40625,"01-1184",799.40625,0,0
"01-1332","v",770.33125,"01-1332",800.33125,0,0
"01-1384","v",770.65625,"01-1384",800.65625,0,0
"01-1472","v",771.20625,"01-1472",801.20625,0,0
"01-1892","a",773.83125,"01-1892",803.83125,0,0
"01-1932","c",774.08125,"01-1932",774.08125,1,0
-Neighbors
#Format: TowerID,TowerIDHex,System ID,Channel,Frequency,Tower Name
204,"T0204",348,"01-1908",773.93125,"Oak Harbor"
215,"T020F",348,"01-2004",774.53125,""
216,"T0210",348,"01-1884",773.78125,"Fremont"
231,"T021F",348,"01-1844",773.53125,"Findlay"
248,"T0230",348,"01-1900",773.88125,""
73's
Ron
"A bank is a place where they lend you an umbrella in fair weather and ask for it back when it begins to rain." Robert Frost.
Tags
700 mhz, central ohio, clark county, dayton, elyria, fayette county, london, lorain county, marcs, marcs p25, marcs-ip, ohio, ohio marcs cuyahoga, southwest ohio, springfield, sticky, urbana, washington ch
Copyright ©2000 - 2016, vBulletin Solutions, Inc.
