Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > Ohio Radio Discussion Forum
Ohio Radio Discussion Forum Forum for discussing Radio Information in the State of Ohio.
  #21 (permalink)
Old 02-09-2013, 7:18 PM
gtaman's Avatar
Originally Posted by WuLabsWuTecH View Post
gtaman, on a good day we have double dispatches occurring... Sometimes it'll dispatch immediately twice in a row (our captain calls this this the 'move your asses faster' dispatch), other times it lags up to a few hours like you described. And then there are those dispatches that dispatch you over, and over, and over, to the point that you've gotten to the scene and it's still repeating...
I'm not really sure what causes it, (nor do I think is anyone else--it's still not fixed) but it's just one of the quirks of the system...
Yeah it seems to be a major problem. I think my favorite is when dispatch says dont touch your buttons and its too late and the computer goes haywire. Happend to my uncle once. he was AOR for a couple hours.
Proud owner of a HARRIS FALCON III AN PRC-152 Multiband Radio.
  #22 (permalink)
Old 02-09-2013, 11:43 PM
Originally Posted by gtaman View Post
Yeah it seems to be a major problem. I think my favorite is when dispatch says dont touch your buttons and its too late and the computer goes haywire. Happened to my uncle once. he was AOR for a couple hours.
Haha, I know the feeling. We touched our button once when we weren't supposed to and it resulted in a trip down to the FAO to get it fixed because it somehow screwed up our Windows. Go figure!
And being stuck on AOR is better than being stuck on AV MDC which is a new button we got in the upgrade. A lot of people started using that not realizing that they had to man their MDC because if you are AV MDC and leave your truck to say, go into McDonald's or gas up the truck, if the radio is busy, they actually won't tone you out over the radio and the next thing you hear is, "Checking your response!"
I remember a battalion chief replying: "Response to where?" Made us all crack up!
  #23 (permalink)
Old 02-13-2013, 7:46 AM
DualReverse's Avatar
Send a message via AIM to DualReverse
Default BN8FG
Battalion 8 fireground if I recall the template correctly is initially set up to be for high rise operations, but for fire runs that occur in Hamilton or Madison Townships where no Columbus equipment is responding, Battalion 181 or Chief 171 will cover as the command officer on the run, and since there is no BN181FG or BN171FG, they can sometimes use BN8.
Anyone remember way back in the day when Battalion 7 fireground was the mutual aid fireground channel? I'll never forget one time Engine 175 took a fire alarm with Columbus, and they marked over the VHF 10-Fire, the dispatcher told them to go to Battalion 7, and they said they didn't have it.
Long live Engine 62.
KQJ-943 forever.
  #24 (permalink)
Old 02-13-2013, 3:45 PM
wa8pyr's Avatar
Technischer Guru
Originally Posted by DualReverse View Post
KQJ-943 forever.
Gotta watch out for those Perry second alarms (dumpster fire and car fire at the same time).
"Engine 92, 943. Signal O! We're in service."
Tom Swisher, WA8PYR
RR Admin/Moderator
PSR500/Pro197/Pro2035+OS535
www.wa8pyr.info
  #25 (permalink)
Old 02-13-2013, 9:40 PM
... for fire runs that occur in Hamilton or Madison Townships where no Columbus equipment is responding ...
I might have to disagree with this statement. Neither township has enough equipment to cover fire runs, so CFD would always be dispatched. Not to mention a batallion chief would be dispatched since the run would be coming out of Columbus Fire Dispatch. The same can be said for Franklin Twp.
  #26 (permalink)
Old 02-13-2013, 10:01 PM
gtaman's Avatar
I may have to make this harder. CFD would only be dispatched per a large incident or a higher command incident. For years when thier was a fire in my neighborhood I would have HAMILTON TWP and MADISONTWP no CFD we actually had the LCK ARFF respond instead. The only time CFD would respond is if it was an apartment or high rise fire. We would need thier ladder truck and an engine. I remember only seeing and hearing them. This was until two years ago. Ever since CFD now dispatches Hamilton CFD will always respond to fire only for MA also for shootings. Medic runs are only hamilton still. They respond now because LCK only will send an engine and they no longer do fire runs only as needed. It was quite confusing back then. It's all changed since CFD started dispatching them.
  #27 (permalink)
Old 02-14-2013, 11:18 AM
wa8pyr's Avatar
Technischer Guru
Incorrect; I've heard runs fairly regularly where Engines 181 and 172, Ladder 172, Rescue 221 etc are on the card and no Columbus equipment.
Columbus isn't always the "be all, end all" of of fire protection in Franklin County; the suburbs do actually work well with one another, in some cases better than Columbus. And it works both ways; there are areas of Columbus where CFD just can't do it alone.
Tom Swisher, WA8PYR
RR Admin/Moderator
www.wa8pyr.info
  #28 (permalink)
Old 02-14-2013, 1:05 PM
Agreed - it's certainly not an impossibility based on the particular location. Although I'm not sure if I'd say that fire runs like that occur regularly.
  #29 (permalink)
Old 02-14-2013, 1:30 PM
gtaman's Avatar
Exactly.
  #30 (permalink)
Old 02-21-2013, 8:59 AM
Fire Alarm in Lockbourne or Obetz:
Engines 171 and 181, Ladder 172, Battalion 181.
There.
  #31 (permalink)
Old 02-21-2013, 10:01 AM
gtaman's Avatar
There.
Don't forget Battalion 4. He responds only if he's not busy usually no lights or siren. If they need him. Sometimes also if bn181 is out of service.
  #32 (permalink)
Old 02-26-2013, 11:46 AM
Columbus Battalion Chiefs don't respond to out of jurisdiction runs unless a Columbus apparatus is responding, they are specifically requested, or they add on as an extra command officer. If Battalion 181 or Chief 171 or Chief 60 or Battalion 51 or Chief 190 are in service, they cover runs in their areas.
