| Ohio Radio Discussion Forum Forum for discussing Radio Information in the State of Ohio. |
12-18-2012, 3:51 PM
The SO freqs on that repeater are dead.
I don't know about the Jail, never listen to them.
12-18-2012, 6:57 PM
Is it possible the jail has the new radios, just not using a talkgroup on the trunked system?
12-18-2012, 7:04 PM
If that is the case, why? They would have to use a repeater and comply with the new rules in 01-01-2013. Would it not be easier and cheaper to use a talk group on the trunked system like Lake Co.? Based on my experience with Cuyahoga County the Jail should be the last to go to a new equipment system.
12-19-2012, 9:17 PM
So, here's another question regarding the Cleveland P25 and the MARCS-IP Systems. I recall, maybe a year or so ago, the county discussing working with MARCS to develop the countywide system, as it was being bulit. Now, all of a sudden, CCSO ends up on the Cleveland one, while the suburbs are tending towards the MARCS-IP.
Are these slated to merge? Did CCSO abandon the MARCS-IP for Cleveland P25 or are things still in flux as these are built out to their full implementation?
Pretty exciting time for our hobby.
73 Joe
12-19-2012, 9:29 PM
73 Joe
Wonder if it's the Sheriff picking up CPD's slack. ie committing to a marine unit. Suggesting support for a joint aviation unit to get CPD flying again?
The new Sheriff has been doing a lot to work with CPD and clean up the department as much as possible. Could very well be that he had to commit to CLE's radio system so they could get it rolling, otherwise it would continue to stagnate for another decade.
12-20-2012, 5:25 PM
Tg 56542
Picked up traffic on 56542 but was unable to determine who it was based upon the nature of the conversation. Continuing to monitor. Still crossing my fingers that the Cuyahoga County Jail will move to the CPS P25.
Reason: typo
12-20-2012, 6:41 PM
CCSO is probably using the CLE system for coverage reasons; it appears from posts I've been seeing here that most of the SO traffic has been related to the jail, the courthouse and other services concentrated downtown. With the Cleveland system having better coverage and capacity in downtown Cleveland (and being primary for CPD), it's logical that they would elect to use it.
As far as the CLE system connecting to MARCS-IP and thus the system for the rest of the county, it's certainly possible and would make sense, but time will tell. Remember, this is government... Cleveland style. Hasn't changed much since I was a near resident of the area.
Tom Swisher, WA8PYR
RR Admin/Moderator
PSR500/Pro197/Pro2035+OS535
www.wa8pyr.info
12-20-2012, 7:42 PM
Limited activity on 56545. Continuing to monitor.
12-21-2012, 6:16 AM
PSR-600 Settings
Hi Group; I have a question for everyone. I have a PSR-500 and PSR-800 and while monitoring the New Cleveland system the 600 does not receive as well as the 800. I understand the the 800 a new generation unit and will track better. The question is has anyone tweeked a 600 / 500 to help with monitoring the system? Thanks, Bill
12-23-2012, 12:32 PM
Anyone having any difficulty hearing the system today ? Could just be my location (Portage County), but it has been crystal clear thru Friday, but yesterday and today, can't acquire the signal at all .. seems odd to suddenly lose signal strength.
KWs
12-23-2012, 8:53 PM
Receiving the system OK from my location. It's not unusual for there to be less traffic on the weekends. Only a handful of departments are currently on the system.
Bud
Pro-34/Pro-97/PSR-500
12-25-2012, 7:58 AM
another cuyahoga county sheriff talkgroup
56544 a sheriff unit was calling 701 on this talkgroup they did not answer he went to the main dispatch channel 56538 and dispatch did answer so heres one more to monitor.
12-26-2012, 3:02 PM
TG 56003 City of Cleveland Streets - snow/salt operations...unsure if dedicated to snow and ice removal and also heard east side operations so also unsure if dedicated to east side
12-26-2012, 5:02 PM
I added 56003 off a submission just now. It also only ID'd it as Streets. Hopefully time will allow for it to be distinguished from 56219, also only ID'd as Streets.
Also, I was considering chang the DB name for this system. The current name of "Cleveland Public Safety (Project 25) System" is misleading. Most of the current users are Public Service, not Public Safety. I would just change the name to "Cleveland (Project 25)".
Thoughts or objections?
Frank
12-26-2012, 5:38 PM
Would make more sense sounds good
12-26-2012, 6:04 PM
System name change sounds good, I changed system name on my favorites a while back.
56219 seems to referred to as OPERATIONS ... I'd suggest change it to Streets Division-Operations
KWs
12-27-2012, 11:52 AM
Hearing activity on 56241 but unable to identify who is generating the traffic.
12-27-2012, 4:41 PM
Tg 56241
I'm confused also
today started out with radio id's same as cleveland trash. 1821xxx
later in day so cuy radio id's 1879xxx.
12-29-2012, 2:47 PM
Unidentified TG's via RR
Tg
56539 Hits 107
56544 Hits 11
56545 Hits 72
56546 Hits 5
56550 Hits 1
56551 Hits 80
All seem to be within the Cuy SO radio Id's.
Any help here?
12-29-2012, 3:02 PM
56546 is a TAC channel for SO, I believe.
I monitored a sting operation and some "other stuff" a while ago that will probably be ENC soon.
Heard mention of "MTAC"? as well on this TG.
