Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > Ohio Radio Discussion Forum
Ohio Radio Discussion Forum Forum for discussing Radio Information in the State of Ohio.
  #761 (permalink)
Old 11-07-2013, 10:50 AM
Default Parma Senior Center
Originally Posted by budevans View Post
Heard multiple calls from "Senior Center" to "either Van" on TG56483, radio id is 1806014. Sounds like the vans don't have the new radio's yet.
Now hearing Senior Center on 56488 with radio id 1806013. Van 45 and Van 41 are replying. Senior Center said they switched radio's. The first radio (1806014) was on TG56483 and the second radio (1806013) is on TG56488 which the Van's were on.
Heard the Parma Senior Center dispatch trying to make calls again today on the wrong channel/TG. Heard dispatcher on TG56484 and TG56483 trying to call (van) 45. Dispatch went back to her original radio and successfully contact (van) 45 on TG56488.
A radio tech needs to check out the radio's given to the dispatcher to see if the Channels/TG are programmed correctly. If the radio's are programmed correctly, give the dispatcher training on how to select the correct Channel/TG.
Bud
Pro-34/Pro-97/PSR-500
  #762 (permalink)
Old 11-07-2013, 11:39 AM
Originally Posted by KB8VJU View Post
I'd second that.
Sent from my VS840 4G using Tapatalk
Check your PMs
  #763 (permalink)
Old 11-07-2013, 1:43 PM
Bud, the RR Database identifies 56488 as Parma Hts Senior Center. You are calling it Parma. Is the RR item mislabled?
Thanks,
John
  #764 (permalink)
Old 11-07-2013, 2:00 PM
Thanks,
John
He initially reported it as Hts so I think he just typoed....
  #765 (permalink)
Old 11-07-2013, 3:07 PM
Default Typo
My bad, it's Parma Hts. Sorry for the confusion.
Maybe I should get some retraining.
Bud
  #766 (permalink)
Old 11-08-2013, 5:23 PM
Default TG56377 Brookpark testing PD console
I monitored testing traffic on TG56377 this morning. The testing was on the console for Brookpark PD. The tests were for Brookpark Aux PD and several patch channels being setup.
Bud
  #767 (permalink)
Old 11-10-2013, 9:17 PM
medic5399's Avatar
Default Has SWRCN moved over?
I haven't heard any FD traffic on SWRCN (including Strongsville's nightly 2200 tone test) tonight
  #768 (permalink)
Old 11-10-2013, 9:50 PM
You must've missed it, SFD tested all stations a bit after 2200 except #2, which was on a run.
  #769 (permalink)
Old 11-11-2013, 7:41 AM
medic5399's Avatar
Thanks for the reply! It seems I'm having some sort of trunking issue with the 106. Somehow the Talk Systems got all switched around
  #770 (permalink)
Old 11-12-2013, 9:31 AM
Default Brookpark PD traffic on TG56377
Monitored traffic from Brookpark PD on TG56377 this morning. The traffic so far has been fairly light.
Note, there is a similar post from davidzimmerman on the Ohio Radio Discussion Forum home page.
Bud
  #771 (permalink)
Old 11-14-2013, 5:28 AM
davidzimmerman's Avatar
Brookpark Police Dispach 56337 Brookpark Police Tac-1 56308
  #772 (permalink)
Old 11-14-2013, 5:30 AM
i was told by the 28th everyone by then should me on cleveland so more talkgroups soon for southwest surbs
  #773 (permalink)
Old 11-14-2013, 1:38 PM
Default 56149
Determined that CPD SWAT, 56149, is encrypted. Got the 'busy' signal.
  #774 (permalink)
Old 11-14-2013, 7:38 PM
Lots of new CPD talkgroups today:
TG56030, 56031, 56032, 56033 and 56083.
Also, heard a reference to OSP with an OSP answer on 56043
Pretty neat watching new TGs appear
  #775 (permalink)
Old 11-14-2013, 7:41 PM
tylerwatt12's Avatar
Yeah saw that too.
I have a live feed broadcasting unknown talkgroups temporarily. It wont sound too great because it's all done via software.
Here's the link if anyone wants to check it out.
tylerwatt12 - live streaming video powered by Livestream
  #776 (permalink)
Old 11-14-2013, 8:27 PM
Default New TG's 56030, 56031, 56032, 56033
Earlier to day, around 5:00 pm I heard the following radio checks and responses.
TG56030 radio check on Region 2
TG56031 radio check on Region 3
TG56032 radio check on Region 4
TG56033 radio check on Region 5
When I got back home this evening (around 7:30 pm) I've heard the same traffic reported by KB8VJU. Some sort of joint Detail with CPD and OSP sharing info (Wants & Warrants) regarding cars that were pulled over for traffic violations. The OSP operation is being coordinated at Steel Yard Commons. Earlier today when the POTUS was in town I heard OSP units from Medina and Lorain reporting to Steel Yard Commons for the Shield Detail.
Bud
  #777 (permalink)
Old 11-14-2013, 8:48 PM
56043 id Region 15 not sure what 56083 is?
  #778 (permalink)
Old 11-14-2013, 9:36 PM
Good catch. Doing a search, back to 7/28, shows TG 56030 identified as REGIONAL 2. Sounds like we've stumbled on a block of INTEROP groups.
  #779 (permalink)
Old 11-14-2013, 9:42 PM
Sounds right, so far besides CPD Detectives/Under Cover and OSP. I've heard the following units involved. Gang unit, K-9 unit (drug sniffing dogs), BAT Van (blood alcohol test), Towing and CPU (prisoner transport).
Bud
  #780 (permalink)
Old 11-16-2013, 11:42 AM
Plenty of activity all night. On top of what has already been mentioned I believe the chopper was working and the vice units. Not a good night to be a “bad guy”. I bet there will be something on the news tonight. Also if you goggle operation shield you can get quite a bit of info on past operations.
Tags
sticky
