Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > Ohio Radio Discussion Forum
Ohio Radio Discussion Forum - Forum for discussing Radio Information in the State of Ohio.
  #1961 (permalink)
Old 04-15-2018, 6:03 PM
Originally Posted by eorange View Post
No more 900 MHz!
Sent from my SAMSUNG-SM-J320A using Tapatalk
Praise the Lord. Never heard the 900 System clear even when in University Circle area. Now getting 100 + hits a day clear off GCRCN.
  #1962 (permalink)
Old 04-15-2018, 6:25 PM
eorange's Avatar
I actually picked it up about 3 or 4 times in recorded history, when the conditions were just right.
√-1 2 π
  #1963 (permalink)
Old 04-15-2018, 7:16 PM
davidzimmerman's Avatar
More Radio Traffic on TG-56729 last time Valley View Police was calling Dispatch still not sure if its a VVPD Channel like on the VHF VVPD had CH-2
  #1964 (permalink)
Old 04-16-2018, 8:00 AM
I have been monitoring 56569-Collinwood High School and have received a 'busy' signal every time. It is encrypted based on my monitoring.
  #1965 (permalink)
Old 05-01-2018, 3:36 PM
I see new RIDs 1863967, 1863977 and 1863978 on Broadview Hts PD TG 56698. I heard "radio service'" testing a few times. Could these be Independence PD since they used 3900s units or new radios for B'view Hts.
  #1966 (permalink)
Old 05-01-2018, 4:33 PM
While it's possible I doubt it. For two reasons.
1st: Based on what I've monitored, I haven't seen a correlation between Unit numbers and RID numbers. Brooklyn Hts: 23xx. Cuyahoga Hts: 29xx, Independence: 39xx, Newburgh Hts: 51xx, Valley View: 73xx.
2nd: Independence as well as Brooklyn Hts. Cuyahoga Hts, Newburgh Hts and Valley View all moved to digital at the same time. Broadview Hts has been full time digital for a while. If I'm not mistaken the only two departments that haven't done a full change over are Seven Hills and Brecksville. One of those would be my guess.
Along those lines, from what I've monitored some RID's are in groups and others appear to be randomly assigned.
Bud
Pro-34/Pro-97/PSR-500/BCD436HP/TRX-1/SDS100
  #1967 (permalink)
Old 05-01-2018, 5:15 PM
I read somewhere that BVHPD was getting some new cars. Maybe these are new radios for them. Or not.
I never heard the unit RIDs - I just logged them - but I did hear radio tests. I think you're right they are not other agencies.
In other news GCRCN signal has been bad for several days - maybe a week on both the WS1065 and BCD996P2. Something has changed.
  #1968 (permalink)
Old 05-01-2018, 5:27 PM
It could be changes in the weather or an issue at a tower. In general terms where are you located? May be others in your area can check their signal strength.
Bud
  #1969 (permalink)
Old 05-01-2018, 6:26 PM
Check your PMs
  #1970 (permalink)
Old 05-01-2018, 10:41 PM
Appear to be Seven Hills PD.
  #1971 (permalink)
Old 05-04-2018, 2:58 PM
jeffb's Avatar
brecksville pd is now dispatching on 56718
  #1972 (permalink)
Old 05-04-2018, 5:37 PM
Over the past several weeks I have recorded 3 series of radio ID's for this Talkgroup.-
1862534-589
1862782-799
1862804 & 1862806
Will have to pay attention to see who (Brecksville-Independence) is using what. I am guessing the 804 & 806 are dispatch RID's.
  #1973 (permalink)
Old 05-04-2018, 9:01 PM
I've identified RID 1862558 as Independence PD so that group probably all is and the 782-799 is likely Brecksville although I stopped logging.
  #1974 (permalink)
Old 05-20-2018, 8:52 AM
Default Cuyahoga Valley Fire
Has anyone figured out the Radio ID's for Brecksville Fire. The RR WIKI has some departments identified but no Brecksville.
John
  #1975 (permalink)
Old 05-24-2018, 1:09 AM
Default TG 56742
I've been monitoring TG 56742 for the last week. I can confirm that it is University Hospital Security.
The main campus in University Circle. Will be submitting.
  #1976 (permalink)
Old 05-30-2018, 12:14 PM
56728 Newburg Hts Police CH-4 i did Submit to the DB
  #1977 (permalink)
Old 06-11-2018, 4:46 PM
56730 Brooklyn Heights PD-4 i did Submit to the DB
  #1978 (permalink)
Old 06-14-2018, 5:07 AM
56729 is Valley View Police CH-4 i did Submit to the DB to make the name change from Valley View PD Talk to VVPD CH-4
  #1979 (permalink)
Old 06-19-2018, 7:58 AM
56703 talkgroup valley school emergency talkgroup
  #1980 (permalink)
Old 06-19-2018, 10:27 AM
Well to the best of my knowledge there are only three public schools and one joint vocational school in the Cuyahoga Valley.
Public (preschool to 12th grade) schools: Brecksville, Cuyahoga Hts. and Independence. The Cuyahoga Joint Vocational School.
Since it's an emergency school TG, it most likely won't be used a lot and will probably be tough to catch any traffic.
Bud
Tags
sticky
