Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > Ohio Radio Discussion Forum
Ohio Radio Discussion Forum Forum for discussing Radio Information in the State of Ohio.
Old 01-13-2013, 10:16 AM
Default Ohio MARCS Question
I know the current Ohio MARCS is not a full digital P25 system... it's the kind that still allows analog traffic. So my question is when they upgrade to the new system, will they be able to do this without any changes to the radios out in the field? And keep all the talkgroups the same? I see the "New" Ohio MARCS section... is this the radio system that will eventually replace the current Ohio MARCS system or will they be kept separate?
Thanks!!!
Old 01-13-2013, 11:10 AM
Thunderbolt's Avatar
Forums Moderator
Thanks!!!
The new MARCS P25 system will eventually replace the old system as it is rolled out across the state. Likewise, all of the subscriber radios currently on the system will need to be flashed, and or replaced with new 700 MHz capable units. This process will take a few years to fully implement throughout the state. When completed, the old system will be permanently deactivated.
73's
Ron
"A bank is a place where they lend you an umbrella in fair weather and ask for it back when it begins to rain." Robert Frost.
Old 01-13-2013, 12:03 PM
wa8pyr's Avatar
Technischer Guru
To amplify and clarify what Ron said...
MARCS-IP will replace the current system, which will then be decommissioned and the 800 MHz frequencies moved over to the new system. The use of 700 MHz frequencies on MARCS-IP is a means not only of getting the system on the air but also a means to increase site capacity once the 800 MHz frequencies are repurposed.
Existing MARCS radios are already mostly capable of P25 operation and won't require flashing, but will need to be reprogrammed to add the MARCS-IP system. Nearly all are already capable of 700 MHz.
Talkgroups will not remain the same but will be all new.
Tom Swisher, WA8PYR
RR Admin/Moderator
PSR500/Pro197/Pro2035+OS535
www.wa8pyr.info
Old 01-13-2013, 12:58 PM
Thanks for the replies!
Old 01-28-2013, 10:45 AM
Send a message via Yahoo to kd8mvc
Default Another MARCS question
Had MARCS wildcard mode on today heard some talk groups from Columbus area [from near Cleveland] heard 45648 and 10992 [OSP and an Ambulance company] is this usual ? or can talk groups skip over tower sites rarely listen to wildcard mode so never heard this before.
Dan KD8MVC
Old 01-28-2013, 12:03 PM
mdulrich's Avatar
MARCS towers only carry traffic that radios that are affiliated with that tower are tuned to. In your example, an ambulance from another area was in your area and was affiliated to the tower you were listening to. This is what allows for statewide communications. By doing this radios are able to communicate all over the state back to their home area and all towers don't have to carry all talkgroups. A trooper from Toledo could be in Cincinnati and Toledo traffic would be heard in Toledo and Cincinnati, but on none of the other towers down I-75.
Streaming the Allen County, Ohio Public Safety Scanner at http://www.broadcastify.com/listen/feed/188
Providing ADS-B data from NW Ohio for http://www.flightradar24.com
Old 01-28-2013, 2:31 PM
Thanks for explaining makes sense.
Dan KD8MVC
Old 01-30-2013, 7:58 AM
So what range of 700 MHz frequencies will be used? I'm just wondering if my GRE 500/600 will still be MARCS-IP capable.
GRE PSR-500 | GRE PSR-600
Old 01-30-2013, 10:04 AM
radioscan's Avatar
Radio Sensei
Send a message via Yahoo to radioscan Send a message via Skype™ to radioscan
Its capable now! I'm listening to the Dayton site on my PSR-500.
The range is 769-775.
Mark, N8ICW
RR Administrator/Moderator
MONIXWeb http://sharedhosting.siscom.net/~mmeec/monix.html
Old 01-30-2013, 10:06 AM
You're good. I monitor MARCS-IP Cuyahoga P25 system which is on 700 Mhz with my GRE 500.
If I'm not mistaken I believe that most if not all of the digital/P25 scanners are capable of receiving the Public Service 700 Mhz freqs.
Bud
Pro-34/Pro-97/PSR-500
Old 01-30-2013, 10:14 AM
Great, I can't afford new scanners!
