Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > Ohio Radio Discussion Forum
Ohio Radio Discussion Forum Forum for discussing Radio Information in the State of Ohio.
  #41 (permalink)
Old 03-15-2013, 7:40 PM
Why wont this work for me in free scan?
  #42 (permalink)
Old 06-23-2013, 11:37 AM
nyscan's Avatar
Is this a digital or analog trunked system?
  #43 (permalink)
Old 06-23-2013, 6:05 PM
OH DB Admin
P-25 systems, like this one, are full time digital audio and 9600 baud control channel.
It is different from a TypeII system in that Type II systems can carry analog audio, digital (P25) audio, or a combination of both (mixed mode).
Frank
  #44 (permalink)
Old 08-16-2013, 8:27 AM
Default APD NOT WORKING
Any one know why I can't receive Austintown Police on the talkgroups that are listed here and worked in June?
  #45 (permalink)
Old 08-16-2013, 1:21 PM
mtindor's Avatar
OH/WV DB Admin
I'm betting the control channel may have changed. The RR Database only lists one control channel, and that is because nobody within earshot of this system ever bothered to submit the full system details (from a trunking program) for us to know what all of the control channels are... at least that's likely the case.
Tune each of the following frequencies with your scanner [if you know how to tune to them manually], and let me know which one of them has a constant (24/7) digital contorl channel belching noise. If you can let me know, I'll update the database to reflect the additional control channel.
The system actually might use all freqs as control channels and may rotate them, or it may be configured to have a primary and a secondary control channel (and we don't know what the other control channel is).
So you may actually be able to help us to help you [and everyone else]
854.76250 856.61250c 857.08750 857.61250 858.11250
Mike / AA8IA
PSR800/PRO197/BCD436HP/BCD536HP
  #46 (permalink)
Old 08-17-2013, 8:23 PM
Default Control Channel
Looks like 857.61250 And thanks for the help.
  #47 (permalink)
Old 08-17-2013, 10:34 PM
mtindor's Avatar
OH/WV DB Admin
You're welcome, and Thank you! I'm glad you were able to ascertain the new CC. I've listed that CC as an additional CC on the system now.
- Mike
Mike / AA8IA
  #48 (permalink)
Old 08-18-2013, 10:08 AM
Default Control Ch
Thanks Mike I guess the 857.61250 is a new channel since I programmed my Pro 106. I added it now works fine. Good work.
Terry
  #49 (permalink)
Old 10-09-2013, 6:29 PM
Can anyone confirm the Austintown talk groups? I have them set to the database but it seems like i'm picking up Boardman only. Thanks!
  #50 (permalink)
Old 10-10-2013, 12:45 PM
mtindor's Avatar
OH/WV DB Admin
If there is any doubt and you feel like you are missing something, then add a wildcard talkgroup. You do that different ways depending upon the type of scanner you're using, and you haven't specified your scanner type.
On a GRE PSR 500/600/800 or RS PRO-197/106 you'd add a Group Wildcard talkgroup. On Unidens, I forget how it is done . It might be called "Open Mode" or "ID Search Mode".
That way you'll hear all talkgroups that are active [and not encrypted]. You might even come across some new [or changed] talkgroups that nobody else has bothered to submit to the DB. And if you do find new ones, we'd appreciate it if you'd let us know.
Mike / AA8IA
  #51 (permalink)
Old 10-10-2013, 12:49 PM
I have a 996XT and it seems that if you don't key in any groups the scanner will just search as you described. Thanks!
  #52 (permalink)
Old 10-12-2013, 9:56 AM
Default Talfgroups
I use ARC500 for my Pro 106 I have the talkgroups listed as follows.
AUSTINTOWN DISPATCH 1500
AUSTINTOWN TACH 2 1501
AUSTINTOWN ROAD 1840
AUSTINTOWN FIRE 1170
BOARDMAN PD 5500
BOARDMAN PD TAC 1 5501
BOARDMAN PD TAC 2 5502
BOARDMAN PD SUPV 5505
MILL CREEK METRO PARK 21500
MILL CREEK METRO PARK TAC 21501
Hope this helps.
Terry
  #53 (permalink)
Old 04-15-2014, 4:46 PM
As of today Boardman Fire no longer appears to be using their VHF frequencies. Are they now on this new system and if so does anyone know the talkgroups?
  #54 (permalink)
Old 04-15-2014, 4:55 PM
Talkgroups are in the message above ^
  #55 (permalink)
Old 04-15-2014, 10:35 PM
W8YSU's Avatar
Boardman Fire does not have a Talk-group shown in that list.......only BOARDMAN POLICE......
  #56 (permalink)
Old 04-16-2014, 9:31 AM
yfdgricker's Avatar
Boardman Fire is now using TG5170. They were testing stations 71, 73 and 74 Monday morning.
Greg Ricker, W8YFD
Youngstown, Ohio, USA
Webmaster, http://www.youngstownfire.com
Greater Youngstown Monitoring Association Vice President, http://www.gyma.org
  #57 (permalink)
Old 04-17-2014, 10:44 AM
yfdgricker's Avatar
Keep an ear on TG1480. I heard some activity on it this morning but I couldn't tell who was using it. It sounded like PD traffic. It doesn't fit the numbering scheme so it might be a new agency on the system.
Greg Ricker, W8YFD
  #58 (permalink)
Old 04-17-2014, 10:54 AM
yfdgricker's Avatar
Talk Group Numbering Schema (in case you haven't figured this out already)
Austintown 1xxx
Fire 11xx
Police 15xx
Road 18xx
Boardman 5xxx
Fire 51xx
Police 55xx
Road 58xx (if they ever switch over)
Mill Creek Park 21xxx
Police 215xx
Greg Ricker, W8YFD
  #59 (permalink)
Old 04-21-2014, 5:22 PM
yfdgricker's Avatar
Austintown Fire was trying to reach 199 on TG1173 this afternoon. Might be a fireground channel.
Greg Ricker, W8YFD
  #60 (permalink)
Old 05-15-2014, 8:38 PM
I noticed the VHF was silent last week when 71 came at me and I was completely unaware. It's nice to have a heads up when a truck comes up the left side of 224. I hope there is no problem in a mutual aid fire. BFD ties up all trucks during a residential fire.
The old VHF PD repeater on 155.490 is still up, but the radio gear was donated to the schools for whatever situations may arise. Not sure of the status of the FD VHF repeater.
