Originally Posted by JerryMcCree
I have a Radio Shack Pro-106 I live in Toledo Ohio I had it programed by a former employee of RS and I get a strong signal on the meter but it dose not sound very good in the store it was great no cutting in or out but in my Apt sounds nothing like it did in the store. I was hopeing somebody on here from Toledo could help me Please re-program this radio or something to spend 400.00 dollars and be on disability is very hard will be very grateful if somebody could help me TY
Your radio is fine and reprogramming won't help you. Toledo is on a P25 simulcast system, which scanners have a hard time with.
The scanner working in the store and not in your apartment a very common complaint when trying to monitor these systems. The most important thing is location, location, location.
The best advice I can give is try moving the scanner around until you find that "sweet spot" in your apartment.
Edit: What type of antenna are you using and which part of Toledo are you in. The key to receiving this system is try to limit the number of towers the scanner can pick up. I know that sounds the opposite of what you would want but trust me.
