Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > Ohio Radio Discussion Forum
Ohio Radio Discussion Forum - Forum for discussing Radio Information in the State of Ohio.
  #101 (permalink)
Old 08-28-2013, 1:18 PM
mdulrich's Avatar
Originally Posted by mtindor View Post
Are you able to snag the alt CC off of that site, mike? I'd guess that if 853.6625 is the current CC, 851.7625 is probably secondary.
Middle Point shows CC 853.6625 & AC 852.7500. Other channels for voice are 851.7625 & 852.3250.
As a side note, it appears that the Wapak site is undergoing rebanding. I'll be gone later this afternoon until later this evening. If someone doesn't beat me to the punch, I'll report the new information when I get back home.
Streaming the Allen County, Ohio Public Safety Scanner at http://www.broadcastify.com/listen/feed/188
Providing ADS-B data from NW Ohio for http://www.flightradar24.com
  #102 (permalink)
Old 08-28-2013, 1:33 PM
Ed. That is correct. All non-rebanded sites should list two red (primary) control channels. That will help you guys out who are waiting for sites to reband. You can program the primary rebanded 850 mhz control channel into a site that is not rebanded yet. Once rebanding occurs, you'll more than likely still hear at least some traffic on the site. You'd still have to set the rebanded trunking tables once a site is rebanded and would still likely want to determine what the alternate CC is if we haven't listed it.
But this should help people "prepare" for their local sites to be rebanded.
Those 850 mhz post-rebanding primary control channels have been added to all not-rebanded sites to help you all in the transition. Those post-rebanding primary control channels were taken from the MARCS-provided PDF mentioned earlier in this thread.
OK - sounds like a plan. I didn't notice other sites that I wasn't interested in.
  #103 (permalink)
Old 08-28-2013, 1:57 PM
mtindor's Avatar
OH/WV DB Admin
Thanks, Mike... on both accounts . I know techs have dialoged with Helpdesk numerous times about Wapak, and I heard them either putting in or removing the directional coupler. So you may very well be right about it being rebanded by end of today. The only time I designate them as rebanded is if (a) I confirm them personally -- only in my neck of hte woods obviously, (b) the confirmation that a site has been rebanded is heard on Helpdesk talkgroup, or (c) somebody else confirms a site has been rebanded.
I'll look forward to hearing the status of Wapak later this eve.
Mike / AA8IA
PSR500/PRO197/BCD436HP/TRX-1
Email: my username @gmail
  #104 (permalink)
Old 08-28-2013, 2:07 PM
wa8pyr's Avatar
Technischer Guru
My confusion on this one in particular is that at some point in the past 867.75 was listed as an alternate control channel. When the site was rebanded I changed it to 852.75. But if Mike i seeing 853.6625 as a CC and we know the primary is 851.7625, just wondering where that left 852.75. I'd rather know specifically the two advertised control channels for that site rather than guessing at the second one at this point.
The bigger picture is that many sites [for which I know there are only two control channels] list more than two control channels. I'd like to get that cleaned up. I'm sure places like the Columbus Simulcast are different, but since the vast majority of sites only use two I would certainly like to verify the two and then clean up any remnants of other alternates listed.
Officially, there is one primary and one alternate control channel per site, although that number includes a reasonable number of widely-separated duplicates across the state, primarily among alternates. This is because the radios only allow up to 128 (if I recall correctly) control channels per system, and more than two per site including frequency reuse would put the total over that number.
The chances of any other than the primary and alternate being used are slim, and if it is necessary, the Motorola radios can search the band until a valid one is found. The neighbor control channel broadcast from adjacent sites helps speed this up if it's necessary.
Tom Swisher, WA8PYR
Lead Database Administrator
PSR500/Pro197/Pro2035+OS535/BCD436HP/TRX-1
  #105 (permalink)
Old 08-28-2013, 3:23 PM
regalman98's Avatar
Default Ghpd
Having trouble with a gre 500 scanner we use in truck. After the reband i cant get any thing to tune in.I looked in the data base and got the new freq. also looked at fcc lic but nothing can anyone help oh yes and firm wear is correct as well
  #106 (permalink)
Old 08-28-2013, 3:42 PM
mtindor's Avatar
OH/WV DB Admin
You need to set up the rebanded trunking tables. Here is one article on how to do it (assuming you are using Win500 to program your scanner):
Custom Band Plans - UtahRadio
Hopefully somebody will be able to help you get things straightened out.
Mike / AA8IA
  #107 (permalink)
Old 08-28-2013, 5:14 PM
sopranosno1's Avatar
Thumbs up
can confirm troy site rebanded.
  #108 (permalink)
Old 08-28-2013, 8:38 PM
mtindor's Avatar
OH/WV DB Admin
Thank you. I'll make the change in the DB if another admin hasn't already. Are you able to confirm any control channels?
Mike / AA8IA
  #109 (permalink)
Old 08-28-2013, 8:48 PM
mtindor's Avatar
OH/WV DB Admin
Techs were at the following sites today. I heard them directly discussing rebanding of Wapak. I don't know if Wapak rebanding is complete, and I don't know if rebanding occurred at any of the other sites. But if you're near any of these sites you should check to see if they have been rebanded:
SOCF (Rosemont)
PEEBLES
OXFORD
WAPAKONETA
Mike / AA8IA
  #110 (permalink)
Old 08-28-2013, 10:46 PM
mdulrich's Avatar
Report on Wapak site rebanding. CC is now 853.2250 and AC is showing 867.5375. Other voice channels are 851.9375 and 854.0875. It looks like there may be some more work to be done tomorrow. I'll report if things change.
  #111 (permalink)
Old 08-28-2013, 11:04 PM
mtindor's Avatar
OH/WV DB Admin
Thanks Mike. That sounds promising.
Mike / AA8IA
  #112 (permalink)
Old 08-29-2013, 11:05 AM
mtindor's Avatar
OH/WV DB Admin
A kind RR user has provided me Unitrunker data of him monitoring the Marysville site. I won't say his name because he might not want me to.
At any rate, Marysville lists the following site neighbors with rebanded control channels. I am not calling these sites as "reband complete" yet, but they certainly are in the process of being rebanded.
712D-007 Riverview - 852.85 cc
712D-031 Orient - 852.6625 cc
712D-032 London - 852.5875 cc
In all likelihood, rebanding on the sites listed above is complete. But they could be "in progress". At any rate, if they aren't completely rebanded yet, they probably will be by end of day.
If anybody can run Unitrunker on the above sites and obtain current information (from a pristine run of Unitrunker, after having deleted any pre-existing site of the same name from Unitrunker), it would be appreciated.
Mike / AA8IA
  #113 (permalink)
Old 08-29-2013, 11:16 AM
mtindor's Avatar
OH/WV DB Admin
Other sites I've heard being worked on that may or may not be rebanded yet, but likely will be very shortly if they aren't, are:
fort recovery - rebanding declared complete (12:26 PM Thurs)
sugarcreek
peebles
gilmore (peoli) - NOT rebanded yet (just checked)
loveland (miami twp)
clarksville (washington twp)
beebe (beebe high ground)
kensington (in progress - one 850 mhz CC, everything else 860 mhz)
Mike / AA8IA
  #114 (permalink)
Old 08-29-2013, 11:21 AM
wa8pyr's Avatar
Technischer Guru
Monitoring with a conventional scanner I can confirm Riverview and Orient as active on the rebanded control channels. Can't quite hear London from home.
Also, traffic on HELPDESK indicates Fort Recovery rebanding is complete.
Tom
Tom Swisher, WA8PYR
  #115 (permalink)
Old 08-29-2013, 11:23 AM
mtindor's Avatar
OH/WV DB Admin
Originally Posted by wa8pyr
Sounds like Fort Recovery is in progress today as well.
Tom
LIstening to their helpdesk comms now. I'm sure they'll be finished shortly on Fort Recovery. McAfee, Mobilecomm, B&C (?) are pretty good about checking in with Helpdesk. I think Staleys (New Phila) are pretty good about it too. The other company that handles the ones in my area don't seem to communicate over helpdesk. Fortunately I can monitor the sites directly and see.
Mike / AA8IA
  #116 (permalink)
Old 08-29-2013, 11:31 AM
mtindor's Avatar
OH/WV DB Admin
Tom
Rgr. Thanks. -- Mike
Mike / AA8IA
  #117 (permalink)
Old 08-29-2013, 11:59 AM
wa8pyr's Avatar
Technischer Guru
Per Unitrunker:
Orient (712D-031):
852.6625 -CC
852.1375
852.4000
853.9500
Can't quite get a clean enough signal on Riverview or London to reliably report anything.
Edit: Amazing what a handheld Yagi can do.
Riverview (712D-007)
852.8500 - CC
851.9500
852.3375
851.6375
Tom Swisher, WA8PYR
  #118 (permalink)
Old 08-29-2013, 12:16 PM
mtindor's Avatar
OH/WV DB Admin
Per Unitrunker:
Orient (712D-031):
CC - 852.6625
852.1375
852.4000
853.9500
Which one(s) are alt ccs? I updated the DB though (using pre-existing alts that were in there but 15 mhz down).
Mike / AA8IA
  #119 (permalink)
Old 08-29-2013, 12:34 PM
rwhanf's Avatar
My UniTrunker Results...
Marysville (712D Site 8)
853.9125 - CC
853.6250 - AC
852.7375
853.0625
854.3625
Richwood (712D Site 61)
852.9625 - CC
852.1125 - AC
851.6000
859.5625
Riverview (712D Site 7)
852.8500 - CC
852.3375 - AC
851.6375
856.0625
857.0125
851.9500
  #120 (permalink)
Old 08-29-2013, 12:39 PM
wa8pyr's Avatar
Technischer Guru
852.4000 is alternate for Orient.
Tom Swisher, WA8PYR
