Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > Ohio Radio Discussion Forum
Ohio Radio Discussion Forum Forum for discussing Radio Information in the State of Ohio.
Old 12-14-2013, 8:56 AM
Jakeportland's Avatar
Default Cedarville Ohio Police Department frequencies
I am using bc436hp
Please be patient with me, I have difficulties understanding, and writing what I need to say about a topic or if I ask for help. Please keep all response simple. Thank You...
Old 12-14-2013, 9:04 AM
radioscan's Avatar
Radio Sensei
They are now using the MARCS-IP system and can be heard from the Greene County Simulcast site.
Ohio MARCS-IP: Multi-Agency Radio Communications (P25) Trunking System, Various, Ohio - Scanner Frequencies
Mark, N8ICW
RR Administrator/Moderator
MONIXWeb http://sharedhosting.siscom.net/~mmeec/monix.html
Old 12-14-2013, 9:09 AM
What scanner should I get for Ohio for this new System
I am using bc436hp
I have a very old scanner
I am using bc436hp
Old 12-14-2013, 9:44 AM
radioscan's Avatar
Radio Sensei
GRE PSR-800 (if you can still find one)
One of the new Uniden Home Patrol scanners coming out BCD436 or BCD536.
Or wait to see what Whistler will come out with in 2014.
Mark, N8ICW
Old 12-21-2013, 10:06 PM
Can the new MARCS IP be monitored with the GRE PSR-500/600 scanners?
I have loaded the new frequencies from RR onto my PSR-600, but, am not hearing much from Greene County. I am located close to Clifton, but still in Clark County.
Thanks.
Old 12-22-2013, 3:31 AM
W8RMH's Avatar
Thanks.
Are you able to clearly receive the control channel from Springfield? It may require a 700/800 MHz. antenna.
BCD996XT BCD396XT BCT15X BCT15 BEARCAT IV YAESU FT60R
Columbus Police Dispatch
Old 12-22-2013, 6:38 AM
TedRHayes's Avatar
Thanks.
You should be able to easily hear the Springfield and Wilberforce 700MHz sites. However, most of the Greene County activity will be heard on the "Greene County Simulcast" system (sub-system?) which is linked to the wider Ohio MARCS-IP system but operates form multiple towers throughout Greene County on 800MHz. One of the towers is just off of Clifton Rd about halfway between 68 & 72, so you should have no issue getting a signal from that tower.
Note: as a simulcast system, all the towers broadcast using the same frequencies, which can lead to multi-path problems in getting good P25 decoding of the control channel and voice channels from many scanners.
Old 12-22-2013, 7:42 AM
I am sure I have the simulcast freq's loaded into my GRE PSR-600, as I used the RR list and I am sure it contains the very latest freq's for Greene County.
I will have to plug in my computer and check to see if the new control channel has been loaded, along with the other freq's.
I have always been able to receive GC units before, including Cedarville PD, Xenia PD and and GCSO units on my PSR-600. I know the MARCS IP system is quite different. The only MARCS I am currently receiving are CCSO, and OSP Posts from this region, which use the older system.
Thanks for the assistance, as always.
Old 12-22-2013, 10:32 AM
TedRHayes's Avatar
As a P25 system you should only need to input the control channel frequency, 858.8875 NFM, in to the scanner (I'm assuming the PSR-600 can do cc only scanning, but don't know for sure).
I was looking the the TGRPs in the RRDB and don't see a specific TGRP for the Cedarville PD. If it exists, it hasn't been identified yet.
Old 12-23-2013, 5:13 PM
TedRHayes's Avatar
Jake,
FYI, I heard units identifying as Cedarville units on the Greene County Sheriff dispatch channel, 20073.
Old 12-24-2013, 3:11 PM
Originally Posted by TedRHayes View Post
Jake,
Ted....I am hearing more and more Greene County traffic on my PSR-600. I have been hearing Beavercreek Fire and the signal is very clear and powerful. Much better than when they were running on VHF.
I have also monitored another GC Fire Department last evening, who had a working a chimney-fire around midnight last evening. Must have been down around Jamestown. I know CFD was called in, probably their tanker for sure. I think I saw Cedarville being dispatched on the old VHF. I think they were dispatched on VHF, when they were on the old EDACs system, also. After units arrived at fire-scene, they switched to TAC-9. Not sure if I heard their traffic, when they switched to 9.
I live right behind the Springfield Airport and monitor the Clark County MARCS system, which has been extremely busy, lately. Probably why I haven't been hearing a lot of Greene Co. traffic.
I still have not heard much from Xenia City. I have started to get more Greene Co. SO last night and today.
