Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > Ohio Radio Discussion Forum
Ohio Radio Discussion Forum - Forum for discussing Radio Information in the State of Ohio.
Old 12-23-2013, 7:32 PM
Location: (Maynard) St.Clairsville Area Belomont County
Default OSP
Can anyone Help me find the New Feq For Ohio State Patrol was told that MARCS has been updating their licenses so not sure if thats the reason i cant pick them up or not but looking for Belmont County Post 7
Old 12-24-2013, 1:38 AM
W8RMH's Avatar
http://forums.radioreference.com/ohi...rebanding.html
Old 12-24-2013, 4:41 AM
Ok this is what I found not sure if its correct I did look in my scanner and found 800 mghz for State patrol but if you click on the link it shows 400 mghz Freq for state patrol I did pick up Kirkwood Tower only heard someone calling in like clocking in ..
WPMB612 (State of Ohio, Ohio State Highway Patrol) FCC Callsign Details
Old 12-24-2013, 4:58 AM
W8RMH's Avatar
You will need Ohio MARCS, program the site nearest to you. The new frequencies are 15 MHz lower than the old ones you had before, however your reband tables need to be set.
Read the link I posted on rebanding on how to set up the rebanding tables in your scanner.
Those 460 frequencies are for their mobile extenders (their walkies to the car), you won't hear anything unless your nearby and probably just one side.
Old 12-24-2013, 5:00 AM
Ok Do you know if Belmont County has been finished with there re banded threw Marcs ?
Old 12-24-2013, 5:11 AM
W8RMH's Avatar
All MARCS rebanding is completed.
Old 12-24-2013, 5:14 AM
Ok butt i cant use like EX Grab from free scan to get the right ones i have to program them in Manual ? I think I read that on here somewhere
Old 12-24-2013, 5:22 AM
W8RMH's Avatar
File:FS rebanding v.8.JPG - The RadioReference Wiki
The link above shows how to setup the reband tables. On the site type drop down menu select Mot Custom/Reband and set up the band plan as indicated. Enter the numbers into the System Band Plan box.
Delete the old frequencies and enter the new control channel frequencies for the St Clairsville site. You can just delete and type them in, you don't need to download anything.
852.9750
853.4125
Old 12-24-2013, 5:32 AM
ok so I would do it like this
852.9750 Lower band Freq
853.4125 upper band Freq
Sorry for all the questions but this scanner has me Nuts l
Old 12-24-2013, 5:37 AM
W8RMH's Avatar
Those frequencies go in the Trunk Frequencies Tab (a different page).
See the link for the numbers to add to the Reband box, (it shows a picture).
Old 12-24-2013, 5:39 AM
W8RMH's Avatar
Exactly like this. Then click on the Trunk Frequencies tab to enter those 2 frequencies I gave you.
Old 12-24-2013, 5:52 AM
Ok I got it one more question then i think i can get it maybe how did you find St.Clairsville Freq ? and will thoses work for Kirkwood Tower its in Belmont County also
Old 12-24-2013, 6:01 AM
Ok I noticed my System Band Plan is blank ?
Old 12-24-2013, 6:07 AM
n8jsw's Avatar
Kirkwood Heights tower isd a differant frequency than St.c HQ tower. Here is a link for all state systems and just go through and put in the frequencies you want.
Ohio MARCS - Multi-Agency Radio Communications Trunking System, Statewide, Ohio - Scanner Frequencies
Just put those in and you should here want you want out of st.c
St Clairsville
Belmont
851.91250
852.55000
852.97500a
853.41250c
858.08750
Old 12-24-2013, 6:21 AM
Well your in St.C as well I see im in Maynard so i really cant hear prob what i should being in this valley if you know any good freq please let me know im fairly knew to leaning this scanner i also thought of buying the new one coming out in jan 2014 where you just enter your zipcode and it automatic updates
Old 12-24-2013, 6:26 AM
n8jsw's Avatar
that would be good but you should be able atleast hear the st.c state tower better than the kirlkwood tower and as for staleys tower i have a hard time hearing it in st.c. Do you have the belmont county system working well enough to where you can hear it? if any problems pm me and maybe we can meet and i can help as much as i can.
Old 12-24-2013, 6:49 AM
I can send you my file you can look it over I really don't hear staleys at all I hear mostly all police departments except East Richland township n flushing when they are working if you can send me your email ill send it i tryed to upload it here and i get invalid file .
Old 12-25-2013, 4:12 PM
Default BCD396xt Help
I had someone make me a file to upload in my BCD396xt Just because i have no idea how to do it but im trying to learn Im determine this scanner wont kick my butt even though its winning the battle so far ..
But can some one tell me how to add Staley Communications im my scanner its under Ohio Belmont County like im not sure how to crate a new group or anything how to add it to the file that someone made for me ..I could try n upload my file to here if someone wants to add it and send it back to me rather try email it because last time i tried to upload it it came up invalid file and wouldn't upload
