Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > Ohio Radio Discussion Forum
Ohio Radio Discussion Forum - Forum for discussing Radio Information in the State of Ohio.
Old 03-27-2014, 10:18 AM
GrumpyAeroGuy's Avatar
Default Warren County Switch to MARCS
I have noticed, most recently yesterday and this AM, that the volume of traffic on the old Moto system has decreased significantly... may actually be coincidental, but it is quite noticeable to me.
I also spoke to a county official yesterday, on an unrelated topic, who mentioned that he was having his radios re-programmed yesterday.
Anyone have any insight as to the status of the switch? Has it already occurred or is it "in process"?
Any info yet on talk groups on the new system?
GrumpyAeroGuy
BC235XLT, PSR500
Old 03-27-2014, 11:03 AM
radioscan's Avatar
Radio Sensei
Default Warren County Swith to MARCS
Still in the process. There has been no activity on the Warren County MARCS-IP Simulcast site. They only have two people reprogramming radios, so it's a slow process.
Sent from my lousy iPhone using Tapatalk
Mark, N8ICW
RR Administrator
MONIX Yahoo Group Page
Old 03-27-2014, 9:52 PM
thank you sir
GrumpyAeroGuy
BC235XLT, PSR500
Old 03-28-2014, 10:13 AM
with the changes to the warren county marcs ip do you guys know if they will keep the uhf fire paging freq
Old 03-29-2014, 10:02 PM
Default Warren co.
As long as fire and ems personnel carry pagers, it should not change. Trunking systems do not affect paging. sometimes simulcasting is done between the two.
Old 04-10-2014, 9:38 AM
radioscan's Avatar
Radio Sensei
The cutover for Warren County to the MARCS-IP system is currently planned for Tuesday May 13th at 10 AM.
Just in time for Hamvention!
Mark, N8ICW
RR Administrator
Old 05-06-2014, 12:26 PM
Just about all of their news can be found below....
Whenever you "join" the WC8EMA club, the president adds everyone to the county telecom emails.
Old 05-07-2014, 1:02 PM
Default Lebanon Tower
I noticed the past two days that I haven't even been able to pick up the control frequency off the Lebanon Tower.
Old 05-07-2014, 1:16 PM
radioscan's Avatar
Radio Sensei
I'm receiving it 99% copy right this moment.
Sent from my PH44100 using Tapatalk
Mark, N8ICW
RR Administrator
Old 05-07-2014, 3:26 PM
Default User error
Disregard...was my fault on a programming error.
Old 05-12-2014, 6:23 AM
looking forward to the switch tomorrow around 10 am.
Old 05-13-2014, 12:27 PM
Okay - they switched ....have we identified any TG's yet ? When I try to import the TG's into my PSR800 it wont let me - just shows X .... I am hearing X83TELECOM - Seems like Fire Dispatch.
Jason
Old 05-13-2014, 1:15 PM
radioscan's Avatar
Radio Sensei
I have already added three new talkgroups since the 1015 switchover. The web service that is used by the EZScan software for your PSR800 won't update until this weekend.
If you can't wait you'll need to program them manually.
Sent from my GT-N8013 using Tapatalk
Mark, N8ICW
RR Administrator
Old 05-14-2014, 4:02 PM
guys here are some talk groups i think i have confirmed so far
XLEBANONPD 48595
XFRANKLINGFIRE 48547-Confirmed
XLEBANONFD 48674-Confirmed
XDEERFIELD TOWNSHIP FIRE OPS 48536-Confirmed
83XTAC2 48693-Confirmed
Old 05-15-2014, 10:34 AM
The reception in the confines of Lebanon is absolutely terrible. However once outside of Lebanon, the reception improves greatly.
Old 05-15-2014, 12:12 PM
Default Re: Warren County Switch to MARCS
In the Landen area, it varies from acceptable to not-so-much.
If I were to assign 10 to the previous system reference reception, I would give the system experience I've had so far a 6.0-6.5 if I were generous...
In your case in Lebanon, does attenuation change your observation?
Sent from my Z10 using Tapatalk
GrumpyAeroGuy
BC235XLT, PSR500
Old 05-15-2014, 1:43 PM
TedRHayes's Avatar
What radio are you using? Are you having an RF receive issue, or a P25 Simulcast issue?
Old 05-15-2014, 7:17 PM
Ted do I need to set the simulcast site on my 346 xt to control channel only ??
Sent from my XT1056 using Tapatalk
Old 05-15-2014, 7:54 PM
TedRHayes's Avatar
If you are talking about a Uniden BC346XT, you will not be able to follow the system with that scanner, I believe it is Analog only. The Warren County Simulcast system is a P25 digital system that is part of the larger Ohio MARCS-IP system.
If you are talking about the BCD396XT, you only need to enter the control channel. ( You also may want to enter the alternate CC).
How well the 396XT performs on the Warren Co Simulcast may be problematic. I know when the local systems switched over to the Greene Co Simulcast system last Nov/Dec, I had marginal performance with my 996XT and my HomePatrol-1; I had some improvement with use of a directional antenna. But I'm most satisfied with the new BCD436XT.
Old 05-16-2014, 10:09 AM
XLEBANONPD 48595
Can you re-check Lebanon FD - that is the same TG Number as the County Dispatch Channel.
Jason
