Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > Ohio Radio Discussion Forum
Ohio Radio Discussion Forum Forum for discussing Radio Information in the State of Ohio.
  #101 (permalink)
Old 03-17-2008, 4:58 PM
FPO703's Avatar
Cuyahoga Falls PD & FD are now on the Summit County Regional 800 System.
Owner: Ohio_MARCS Yahoo Group
Equipment: PRO-96, BCD396T, BC246T, PRO-92, BC235XLT, BC245XLT, PRO-2016.
  #102 (permalink)
Old 03-18-2008, 5:26 AM
Akron Metro Park Rangers testing on TG 39568, digital.
  #103 (permalink)
Old 04-15-2008, 4:17 PM
Send a message via AIM to eekdood
Now I'm a little frustrated. I bought a BCT-15 a few months back to track Cuyahoga Falls, Stow, and surrounding FDs. Now that most have made the move to the Regional Radio, this has become the very expensive paperweight. Unless I'm missing something here, I'm limited to Stow and Hudson, right??
  #104 (permalink)
Old 04-15-2008, 8:40 PM
snjct2000's Avatar
Stow, Hudson, Boston Hts., Macedonia, Twinsburg and all of Portage County (except O.S.P.). But in a few months, you won't be able to hear Stow PD / FD. They are in the process of joining the Summit 800 mhz. system too. Might be time to consider a digital scanner if you want to monitor them.
Good luck!
  #105 (permalink)
Old 05-03-2008, 9:48 AM
I just bought a BCT-15, can you explain your statement to me??? I am just getting into this trunking stuff.
Jerry
  #106 (permalink)
Old 05-03-2008, 11:56 AM
Default Tg 36848
I've been monitoring Summit County for a couple months now.. RR has TG 36848 as 'Springfield Twp Police Ops '... Others have probably made note of this,, but I am very sure this TG is a dispatch for the Summit County Sheriff's department.... Feedback appreciated...
Brian
  #107 (permalink)
Old 05-03-2008, 5:43 PM
N8IAA's Avatar
Jerry
It is a digital system. BCT-15 is an analog only trunktracker, not a digital like the 996, 396, PSR500, PSR600 radios.
Larry
  #108 (permalink)
Old 05-03-2008, 8:33 PM
Larry
OOPs! I looked it up and figured it out earlier. I called Universal Radio and got a RA# and ordered a GRE 600 in its place.
Thanks for the pointer and accurate info.
Jerry
  #109 (permalink)
Old 05-26-2008, 6:57 PM
does anyone know if northfield center uses a seperate dispatch channel for the SO which patrols their township? or do they use the main SO dispatch channel as well...
-Andrew
BC246T
BCD396T
Pro-95
  #110 (permalink)
Old 07-01-2008, 7:56 AM
KWs's Avatar
KWs KWs is offline
Stow Regional Dispatch Center (part of Summit Regional 800) opening delayed until mid-August at earliest .. Tallmadge will continue to dispatch for Tallmadge & Mogadore until then.
KWs
  #111 (permalink)
Old 07-09-2008, 9:05 PM
Default Copley/Bath/Fairlawn/Richfield
Talked to a Bath PD officer I know tonight. Bath/Copley/Fairlawn cut-over to Summit800 is IMMINENT!!! Radios are installed. They are being told move date is around 8/7, definitely before Community Day (mid Aug?).
Richfield is still waiting for new towers in the NW section of the county. There are too many dead spots, as Valley JFD and Penninsula can attest.
Frank
  #112 (permalink)
Old 07-14-2008, 7:46 AM
KWs's Avatar
KWs KWs is offline
Cuyahoga Falls begins providing all safety services including dispatch to Silver Lake at 10:00 July 15.
Their unit MDB's have mapping capablities (with GPS vehicle locators) to asssit repsonding units in locating addresses.
Also.. Stow will begin operation of their dispacth center Aug 29.
Tallmadge dispatch ops & dispatchers will transfer to Stow on that date.
KWs
  #113 (permalink)
Old 07-14-2008, 11:57 AM
snjct2000's Avatar
Will Stow then be on the Summit 800 mhz system when Tallmadge joins them?
  #114 (permalink)
Old 07-15-2008, 6:39 AM
KWs's Avatar
KWs KWs is offline
That's the grand plan .. Stow FD may be ready to go 800 at that time .. I do not believe Stow PD has the radios yet to switch. So you'll have different departments operating on diferent systems run by the same dispatch center. This is going to be ... let's just say, bizzare.
KWs
  #115 (permalink)
Old 08-02-2008, 8:36 PM
A couple of new TGs to keep an ear on:
38800 - heard "4 to 7 on car to car", possible Cuyahoga Falls PD Car To Car
61616 - heard "1507 to 1501", possible Copley FD, talking about helo arriving (sounds like festival traffic)
  #116 (permalink)
Old 08-06-2008, 8:04 AM
38800 appears to be Silver Lake PD Car-to-Car. DB change submitted.
  #117 (permalink)
Old 08-06-2008, 11:50 AM
KWs's Avatar
KWs KWs is offline
TG 36368 appears to be Munroe Falls Fire / EMS Dispatch, from the Cuyahoga Falls Dispatch Center.
Need further monitoring of the TG ID to confirm .. no change submitted to database until further documentation.
KWs
  #118 (permalink)
Old 08-09-2008, 11:07 PM
hogwmn's Avatar
Unhappy Tallmadge Pd
Hi how do get the new Tallmadge Pd I know they on Summit County 800 mhz system but I lost Summit County to , any one can help me with my new Pro 2096 thanks
Originally Posted by fpo701 View Post
Quick update:
I've been (as always) listening in search mode today. I've heard some traffic on 36976. Heard 100s unit numbers (possible Springfield PD Lt). I just heard a 901 unit number. That's definitely Springfield Twp PD. Sounds like South Summit (Green, Springfield, Lakemore, Coventry, Franklin) are ready to move.
Here's the odd thing. Tallmadge and Mogadore did a ton of individual radio testing before the move. This is the first I've heard anything on this TG. On the flip side, Valley FD did like no testing.
Frank
  #119 (permalink)
Old 08-10-2008, 11:02 AM
snjct2000's Avatar
I live in Brimfield and have a pro-2096 and can help you with yours. It's very easy. Send me a private message.
  #120 (permalink)
Old 08-18-2008, 5:16 PM
hogwmn's Avatar
akron digital police disp freq update = 852.1124 , 852.3875 . 853.5125 .852.3125 . 853.3875 .866.4875 police freq are good to
