NXDN ENC
OHIOSCAN
Lorain Cnty, OH
More ENC NXDN sites popping up
424.0625 KQB214 E.CLE PD
424.9625 NXDN96 RAN:27 (ENC)
7000 (BASE)
7009 (CBS 909)
7612 (CBS 912)
7620 (CBS 920)
7621 (CBS 921)
7624 (CBS 924)
7626 (CBS 1126)
464.6875 NDXN96 "ENC"
464.9375 NXDN96 RAN:40 "ENC"
31000 (SECURITY BASE)
31002 (SP UNIT 2)
31018 (SP UNIT 18)
31019 (SP UNIT 19)
31026 (SP UNIT 26)
jdolina
Lorain Ohio
424.9625 I believe is the ican charter schools I have seen TG with i can XX
424.975 RAN:27 same as above
I can add the following as NXDN enc I have found
463.775 RAN:40 Which I believe is Lutheran hospital security based on TG LU SEC LU BASE
WQOQ369 (CLEVELAND CLINIC) FCC Callsign Details
461.7375 RAN:44
463.2625 RAN:35
464.6875 RAN:30 TG's base and xBUS
16b
Central Ohio
Kind of ironic you didn't realise that given your profile pic.
I have programmed and used encryption on various two-way radios, and I can't recall ever seeing it referred to as "ENC." I believe scanners use this terminology? It is confusing/misleading because it is not an acronym, yet it is almost always written using ALL CAPS.
OHIOSCAN--thanks for the information. The reason I was confused was because you also listed additional information like "BASE" and "BUS 43" that one would normally not be able to determine without listening to the radio traffic. I know Nexedge radios have a text ID field that can be transmitted along with the regular numeric unit ID. Is that where you are getting this information?
OHIOSCAN
Lorain Cnty, OH
Been scanning since 1981 and DSD+ is the most usefull tool for collecting radio system data I have used
Unitrunker is another great program also.
OHIOSCAN
Lorain Cnty, OH
Random NXDN logged notes
420.0375 NXDN48
422.9625 NXDN48 SITE R202-36
424.0625 NXDN96 RAN:13 KQA214 (ENC)
RIDS: 10,27,30
424.9625 NXDN96 RAN:27 (ICAN CHARTER SCHOOL?)
7000 (BASE)
7009 (CBS 909)
7612 (CBS 912)
7620 (CBS 920)
7621 (CBS 921)
7624 (CBS 924)
7626 (CBS 1126)
452.7000 NXDN96 VOICE
453.1000 NXDN96 VOICE RAN:1
453.2750 NXDN96 VOICE RAN:13
453.2875 NXDN96 VOICE
453.5250 NXDN96 VOICE RAN:19
TG
RID 33 DISPATCH
RID 221 UNIT 527
RID 366 UNIT 762
RID 2221 UNIT 539
460.3875 NXDN96 SITE L231-1
461.4000 NXDN96 VOICE
461.6250 NXDN48 VOICE RAN:19
461.7375 NXDN RAN:44
463.2625 NXDN RAN:35
464.6875 NXDN RAN:30
463.9375 NXDN48 VOICE (UNID SCHOOL)
464.0750 NXDN96 SITE L290-1
464.2125 P25 (ENC)
TG# 1
RIDS
1804923
1804925
7604910
464.2750 NXDN96 VOICE
463.7750 NXDN RAN:40 LUTHERAN HOSPITAL SECURITY
464.5625 NXDN48 VOICE RAN:10
464.6875 NXDN96 RAN:30 (ENC)
5000 [BASE]
5007 [BUS 43]
31000 (SECURITY BASE) ENC
31002 (SP UNIT 2)
31018 (SP UNIT 18)
31019 (SP UNIT 19)
31026 (SP UNIT 26)
NEXTEDGE SITES
SITE 127-1 BASF ELYRIA
451.3625 NXDN96 SITE-L127-1 RAN:1 (CH-1 CC)
451.5375 NXDN96 SITE-L127-1
452.1375 NXDN96 CC SITE 127-1
452.4875 NXDN96 CC SITE L127-1
452.6875 NXDN96 VOICE / CC SITE L127.1 RAN:1 (CH-3 CC)
453.1000 NXDN96 VOICE SITE L127-1 RAN:19
453.2750 NXDN96 VOICE SITE:L127-1
453.5250 NXDN96 VOICE SITE:L127-1 RAN:19 (CH 3 CC)
TG#
2 RID 164, 169{THIERY}, 134{GAVALEK}
SITE L191-1 ELECTROCOMM UHF NE OH
PARMA
WPQC999
422.3375*VD
422.6125*V
424.5625*CC
424.7125
424.7625
424.9375
424.9625
424.5625 NXDN96 SITE L191-1 (CH 2(SCC) 4, 26, 182 CC, 216, 448, 1002)
422.3375 NXDN96 SITE L191-1 RAN:1
422.6125 NXDN96 SITE L191-1 RAN:1
SITE L191-1
SITE L191-2 CC=216
TG#
CH04 422.3375
CH26 422.6125
CH182
CH216
TG
7500 BASE ENC
7700 ENC
RID 7547
RID 7553 UNIT 53
RID 7710 PICKUP 10
RID 7811 TRUCK 11
RID 7822 F/LOAD 22
RID 7825 F/LOAD 25
RID 7826 F/LOAD 26
RID 7827 F/LOAD 27
RID 7828 F/LOAD 28
SITE 285-1
152.4125 NXDN96 SITE:L285-1 RAN:1
152.3250 NXDN96 SITE:L285-1 RAN:1
W5RGP
Charlotte Tn
How hard is dsd to get setup? My local le went nxdn a while back and would like to seek out all the info for that site
nrf
Ohio
this seems interesting, and inexpensive, but has anyone made the jump from hand tuning a channel to following a trunked system?
wd8chl
Fwiw-420.0375 is out of the band. The allocation starts at 422.000 up to, but not including, 430.
mtindor
OH/WV DB Admin
Carroll Co OH / EN90LN
424.9625 is licensed to ElectroComm. The "CBS" activity you guys have seen/see on there is likely an I CAN charter school somewhere, or the overseeing network.
L191 system (Electrocomm NXDN UHF) - https://www.radioreference.com/apps/db/?sid=9005
These are encrypted:
TG: 7000 ENC Appears to be I Can charter schools
TG: 7700 ENC looks like some place with a lot of front-end loaders
TG: 7800 ENC Appears to be a roll-off container company
All heard off of 191-1 Parma site.
Code:
NEXEDGE96, 191,       7000,     7000,     50,  Normal,      27,  2018/11/28 14:16,  *" BASE"
NEXEDGE96, 191,       7000,     7003,     50,  Normal,      29,  2018/11/28 14:06,  *"CBS 1176"
NEXEDGE96, 191,       7000,     7006,     50,  Normal,      15,  2018/11/28 14:02,  *"I CAN 6"
NEXEDGE96, 191,       7000,     7007,     50,  Normal,      12,  2018/11/28 14:15,  ""
NEXEDGE96, 191,       7000,     7008,     50,  Normal,      10,  2018/11/20 16:30,  *"I CAN 8"
NEXEDGE96, 191,       7000,     7009,     50,  Normal,      21,  2018/11/28 14:18,  *"I CAN 9"
NEXEDGE96, 191,       7000,     7010,     50,  Normal,      14,  2018/11/28 14:17,  ""
NEXEDGE96, 191,       7000,     7012,     50,  Normal,      28,  2018/11/28 14:13,  ""
NEXEDGE96, 191,       7000,     7017,     50,  Normal,       4,  2018/11/28 14:13,  *"I CAN 17"
NEXEDGE96, 191,       7000,     7018,     50,  Normal,       1,  2018/11/20 16:27,  *"I CAN 18"
NEXEDGE96, 191,       7000,     7600,     50,  Normal,       3,  2018/11/28 14:12,  ""
NEXEDGE96, 191,       7000,     7608,     50,  Normal,      59,  2018/11/28 14:18,  *"CBS 908"
NEXEDGE96, 191,       7000,     7611,     50,  Normal,      13,  2018/11/28 14:14,  ""
NEXEDGE96, 191,       7000,     7612,     50,  Normal,       2,  2018/11/20 16:30,  *"CBS 912"
NEXEDGE96, 191,       7000,     7616,     50,  Normal,      29,  2018/11/28 14:18,  ""
NEXEDGE96, 191,       7000,     7617,     50,  Normal,       2,  2018/11/27 20:57,  ""
NEXEDGE96, 191,       7000,     7619,     50,  Normal,       9,  2018/11/28 14:11,  *"CBS 919"
NEXEDGE96, 191,       7000,     7620,     50,  Normal,       8,  2018/11/28 14:18,  ""
NEXEDGE96, 191,       7000,     7621,     50,  Normal,      10,  2018/11/28 14:14,  ""
NEXEDGE96, 191,       7000,     7622,     50,  Normal,      16,  2018/11/28 14:16,  ""
NEXEDGE96, 191,       7000,     7623,     50,  Normal,      13,  2018/11/28 14:06,  ""
NEXEDGE96, 191,       7000,     7624,     50,  Normal,       3,  2018/11/19  7:08,  ""
NEXEDGE96, 191,       7000,     7629,     50,  Normal,      67,  2018/11/28 14:16,  *"CBS 1129"
NEXEDGE96, 191,       7000,     7630,     50,  Normal,       1,  2018/11/27 20:58,  ""
NEXEDGE96, 191,       7000,     7650,     50,  Normal,      32,  2018/11/28 14:14,  ""
NEXEDGE96, 191,       7000,     7651,     50,  Normal,      52,  2018/11/28 14:18,  ""
NEXEDGE96, 191,       7000,     7652,     50,  Normal,       7,  2018/11/28 14:15,  *"....F 60........"
NEXEDGE96, 191,       7000,     7654,     50,  Normal,       3,  2018/11/28 14:03,  ""
NEXEDGE96, 191,       7000,     7656,     50,  Normal,       3,  2018/11/19  7:00,  ""
NEXEDGE96, 191,       7000,     7658,     50,  Normal,       5,  2018/11/28 14:12,  ""
NEXEDGE96, 191,       7000,     7664,     50,  Normal,      24,  2018/11/28 14:18,  *"....528"
NEXEDGE96, 191,       7000,     7665,     50,  Normal,       1,  2018/11/28 14:05,  ""
NEXEDGE96, 191,       7000,     7666,     50,  Normal,      15,  2018/11/28 14:07,  ""
NEXEDGE96, 191,       7000,     7667,     50,  Normal,      59,  2018/11/28 14:18,  ""
NEXEDGE96, 191,       7000,     7668,     50,  Normal,      15,  2018/11/18 17:18,  ""
NEXEDGE96, 191,       7000,     7672,     50,  Normal,      26,  2018/11/28 14:18,  ""
NEXEDGE96, 191,       7000,     7673,     50,  Normal,      11,  2018/11/20 16:30,  *"CBS 1182"
NEXEDGE96, 191,       7000,     7674,     50,  Normal,       3,  2018/11/28 14:08,  ""
NEXEDGE96, 191,       7000,     7678,     50,  Normal,      19,  2018/11/28 14:15,  *"CBS 538"
NEXEDGE96, 191,       7700,     7723,     50,  Normal,      12,  2018/11/28 14:15,  *"F/LO....3"
NEXEDGE96, 191,       7700,     7724,     50,  Normal,       4,  2018/11/28 14:14,  *"F/LOAD 24"
NEXEDGE96, 191,       7700,     7725,     50,  Normal,       7,  2018/11/28 14:15,  ""
NEXEDGE96, 191,       7700,     7726,     50,  Normal,       2,  2018/11/28 14:13,  *"F/LOAD 26"
NEXEDGE96, 191,       7700,     7729,     50,  Normal,       7,  2018/11/28 14:15,  *"F/LOAD 29"
NEXEDGE96, 191,       7700,     7730,     50,  Normal,       3,  2018/11/19  5:11,  ""
NEXEDGE96, 191,       7700,     7731,     50,  Normal,      30,  2018/11/28 14:16,  *"F/LOAD 31"
NEXEDGE96, 191,       7700,     7732,     50,  Normal,       2,  2018/11/28 14:17,  ""
NEXEDGE96, 191,       7700,     7733,     50,  Normal,      19,  2018/11/28 14:18,  ""
NEXEDGE96, 191,       7703,     7703,     50,  Normal,      75,  2018/11/28 14:16,  *"BASE"
NEXEDGE96, 191,       7800,     7702,     50,  Normal,     144,  2018/11/28 14:18,  *"BASE"
NEXEDGE96, 191,       7800,     7741,     50,  Normal,      10,  2018/11/19  7:42,  *"R\OFF 41"
NEXEDGE96, 191,       7800,     7836,     50,  Normal,       6,  2018/11/28 14:11,  *"R\OFF 36"
NEXEDGE96, 191,       7800,     7837,     50,  Normal,      11,  2018/11/28 14:15,  *"R\OFF 37"
NEXEDGE96, 191,       7800,     7838,     50,  Normal,       5,  2018/11/19  7:56,  *"R\OFF 38"
NEXEDGE96, 191,       7800,     7842,     50,  Normal,       8,  2018/11/19  7:50,  *"R\OFF 42"
NEXEDGE96, 191,       7800,     7843,     50,  Normal,      14,  2018/11/19  7:27,  *"R\OFF 43"
NEXEDGE96, 191,       7800,     7844,     50,  Normal,      30,  2018/11/28 11:51,  *"R\OFF 44"
NEXEDGE96, 191,       7800,     7845,     50,  Normal,       4,  2018/11/19  7:33,  *"R\OFF 45"
NEXEDGE96, 191,       7800,     7846,     50,  Normal,       3,  2018/11/19  7:51,  *"R\OFF 46"
NEXEDGE96, 191,       7800,     7848,     50,  Normal,      28,  2018/11/28 14:18,  *"R\OFF 48"
NEXEDGE96, 191,       7800,     7849,     50,  Normal,       2,  2018/11/28 11:50,  *"R\OFF 49"
NEXEDGE96, 191,       7800,     7850,     50,  Normal,       3,  2018/11/19  7:58,  *"R\OFF 50"
NEXEDGE96, 191,       7800,     7851,     50,  Normal,      14,  2018/11/19  7:46,  *"R\OFF 51"
NEXEDGE96, 191,       7800,     7852,     50,  Normal,       2,  2018/11/19  7:15,  *"R\OFF 52"
NEXEDGE96, 191,       7800,     7853,     50,  Normal,      10,  2018/11/28 11:48,  *"R\OFF 53"
NEXEDGE96, 191,       7800,     7854,     50,  Normal,       9,  2018/11/28 14:13,  *"R\OFF 54"
NEXEDGE96, 191,       7800,     7855,     50,  Normal,      12,  2018/11/19  7:57,  *"R\OFF 55"
NEXEDGE96, 191,       7800,     7856,     50,  Normal,      20,  2018/11/28 11:50,  *"R\OFF 56"
NEXEDGE96, 191,       7800,     7857,     50,  Normal,       9,  2018/11/28 14:15,  ""
NEXEDGE96, 191,       7800,     7858,     50,  Normal,       4,  2018/11/28 11:47,  ""
NEXEDGE96, 191,       7800,     7859,     50,  Normal,      11,  2018/11/28 11:48,  *"R\OFF 59"
NEXEDGE96, 191,       7800,     7860,     50,  Normal,      11,  2018/11/28 14:08,  *"R\OF...."
NEXEDGE96, 191,       7800,     7861,     50,  Normal,      17,  2018/11/28 11:52,  *"R\OFF 61"
NEXEDGE96, 191,       7800,     7862,     50,  Normal,      17,  2018/11/28 14:18,  *"R\OFF 62"
mbstone99
Hamilton, Ontario
> 420.0375 NXDN48
The 420.0375 could be the OnQ network (System 202) site in Chatham, Ontario (Site 14) while the 422.9625 is the Tilsonburg, Ontario site for the same network.
Matt
