Any idea who this is?
lucky43113
Central Ohio/Pickaway County
I'm in Pickaway county they have been talking all day but not sure who they are they have been watching certain vehicles but they do not sound like any law enforcement
This is the info i got from RR database
54508 d4ec D XLECOMM-3 Local Event Communications 3 Interop
fyrfyter33
Cincinnati, OH
XLECOMM-3 is a Statewide interop talk group on the MARCS system. If you have a newer radio, like an APX, you likely have this TG on it. It's coordinated by the state, when needed for use.
fyrfyter33
Cincinnati, OH
Thanks i have a 996p2
I meant an actual communications radio on the MARCS system.
I have an APX6000, that can access this. It's one of many statewide interop talk groups on the MARCS system.
It is designed so that in a major emergency, like an EMAC response, my radio from a county in SW OH will work anywhere in the state, without any need for reprogramming or changing. It is also capable of using the NIFOG national talk groups, for inter-state responses.
Hope that helps explain things.
lucky43113
Thanks for the explanation
wa8pyr
Technischer Guru
Staff member
Lead Database Admin
Ohio
Actually, only use of the XECOMM talkgroups is coordinated by the state. The XLECOM talkgroups are available by merely saying "is this talkgroup in use" and if there's no answer, away you go. Of course, your local policy may vary.
