Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > Ohio Radio Discussion Forum
Ohio Radio Discussion Forum - Forum for discussing Radio Information in the State of Ohio.
  #41 (permalink)
Old 12-22-2017, 11:39 AM
jdolina's Avatar
Have you been able to just hold on the frequency and see if you receive anything?
Are the other Lorain channels also set as priority? Try only setting EPD to priority.
On the 1065 all conv channels have equal priority might just be missing traffic to busier channels.
BC780XLT, BCD996XT, Pro-106, BCD436HP, SDR# DSD+, TRX-2
  #42 (permalink)
Old 12-22-2017, 11:42 AM
Nasby's Avatar
Originally Posted by hdalgleish View Post
Nasby...I set it just as you said and still nothing. I don’t get it. I can hear everyone else perfectly.
Try setting the Squelch Mode to "Search". Then don't do anything with the Squelch Code setting.
Then leave the scanner set to pause on the EPD channel. This will allow you to only monitor EPD to see if you are receiving them or not.
It's hard to say for sure if you are receiving the channel if you are scanning a bunch of other stuff at the same time.
  #43 (permalink)
Old 12-22-2017, 5:34 PM
Thank you both so much! When I just stay on EPD, I can hear them. When I start scanning, I don't.pick them up. I don't have anything else set to priority.
  #44 (permalink)
Old 12-22-2017, 6:42 PM
davidzimmerman's Avatar
are you sure their in the scan list?
  #45 (permalink)
Old 12-23-2017, 6:25 AM
I checked the scan list and all are on List 1
  #46 (permalink)
Old 12-23-2017, 8:11 AM
Send me your file radios4bill@gmail.com
  #47 (permalink)
Old 12-23-2017, 10:00 AM
Thank you radios4bill...I tried to save list, but it just saves as a bin file. Can you have squelch dial too high? I had it turned to max and I'm wondering if that could be the problem. I'm going to try to turn it down to see, if that does anything.
  #48 (permalink)
Old 12-23-2017, 10:01 AM
I'm not the brightest bulb in the box, when it comes to scanners!
  #49 (permalink)
Old 12-23-2017, 10:05 PM
Default Set the squelch as low as possible
Yes... You set the squelch just high enough to stop the static at the end of a transmission on analog/conventional frequencies.
If the squelch is fully off (open) at the 7 O'clock position, then typically you would set the squelch at the 9 or 10 O'clock position.
Bud
Pro-34/Pro-97/PSR-500/BCD436HP/TRX-1
  #50 (permalink)
Old 12-24-2017, 7:27 AM
Thank you budevans. Have a Merry Christmas!
