145.62
While this is in the 2m band, the freq is unusual one as there is normally 20khz spacing here with the second digit to the right of the decimal an odd number on this part of the band. Repeater outputs 145.11-145.49. Packet ops would be between 145.51-145.99. Of course there are some folks who deviate from the band plan. In any case, if there are no packet ops around then it's possible for someone to use that freq for shuttle retransmissions. You should hear a CW ID every 10 minutes while NASA Select audio is up.
