yep, it's not locked out... figured that was the only thing anyone hasn't mentioned so far... I know it sounds completely simple to figure but honestly I've double checked and rechecked my programming.... and I KNOW the bank and the CC freq. are both set for MOT... I've programmed this scanner using Win96 lots of times... as far as a p96 file, I actually was just fumbling around in one bank and just locked out everything but the programmed from hand, Oxford CC that I put ontop of one of my MARCS channels (since it's in my MARCS bank - which was already set up for MOT bank). Just wanted to see that I could pick the darn thing up before I started putting a set place for it.... If I'm picking up the other 800freq. in the table, something weird is going on... but I'm thinking maybe because I'm not too close to Oxford, but should be able to pick it up I would think, that maybe the voice channel info I'm picking up is from another closer system... I rode around with scanner in truck and didn't have any luck... watched the CC and it seemed to bounce around alot while mobile... I'm not far from 27 and 275 so I'll hop up that way soon and see if the mile or so difference makes any change in reception ability.... I also have a friend with a pro96 that maybe I'll borrow for a short stint and make sure I don't have something goofy going on with mine!
