digitalanalog
Pro 2053
Scantenna @30'
Rural Northeast Ohio.
O.k., I have just started messing with the 800 trunking on the scanner.
I have endered abunch of 800MHz cahnnels but have not herd anything
I do live rural and no local dept. use trunking.
But i should at least be able to hear something
even if it's far off and full of static.
Maybe i'm not setting the scanner up properly?
Anyway, is they any specific 800MHz trunk freq, i could put in just
to see if i have the scanner set up properly?
My local area is Leetonia Ohio.....44431
Not much around, nearest would be Warren ohio (trunked) or
austintown ohio (trunked)
Anyone..........
Thank You in advance for your time.
Scantenna @30'
Anyone..........
