Belmont County 911 (and MARCS - St. Clairsville) are being fed on www.scanmiamivalley.com (thanks Gordon) in the NorthEast section.
It is also available on http://www.ovscan.com along with Jefferson Co.
An 800 mhz antenna for the handheld will be purchased shortly, which will give better MARCS signal and likely allow reception of Bridgeport MARCS as well as St. Clairsville MARCS.
Scanner is being run in ID Search mode, so no talk groups are locked out.
This feed is not mine - it belongs to a friend of mine who does not frequent this board and wishes to remain nameless. But for anyone caring to listen to the Belmont Co area, I just wanted to let you know that I'm not the one providing it so don't thank me
The feed is using a BC296D.
