Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > Oklahoma Radio Discussion Forum
Oklahoma Radio Discussion Forum Forum for discussing Radio Information in the State of Oklahoma.
Old 09-06-2012, 6:50 PM
sslater0679's Avatar
Default Encrypted or not
Every now and than the Claremore PD will say switch over, when they do its to the Claremore PD 3 channel. When it comes through I can barley make out some of the work, it kind of sounds like a high pitched robot talking. My question is, is it supposed to be that way or could I have something out of place. Claremore is using the LTR system. Also its currently running on my feed, should I lock it out, or leave it?
Old 09-06-2012, 10:49 PM
mam1081's Avatar
Sounds like it might be voice inversion. Sometimes it sounds like a robot, other times it sounds like donald duck...
I'd listen in and see if that channel was always like that or if it was in the "clear" occasionally. If it's in the clear, I'd leave it on your feed. Delete if it's always garbled.
Old 09-09-2012, 7:43 PM
HogDriver's Avatar
I've noticed one of my local PD's go to a direct channel that's digital. It wasn't going through the repeater so what your hearing might be the same deal but your not close enough to get a strong signal so what you do hear is broken.
