Ringing on Tulsa OKWIN
I have a pro-205 scanner. When listening to tulsa's 800mhz system, i get a high pitch ringing sound in some areas of tulsa and broken arrow. If i hit attenuation it stops. Could I be overloading the front end? I did finally get a 3db curly q antenna that is made by motorola and i dont recall it doing this before or not. Another thing, in some areas I am getting alot of static. Im not sure if this is cause i have a low feed line or not. Im running dual sheild rg-58 at 17 ft in car. Any help?
Pro-2055
Pro-106
Motorola 3db Curly-Q
Larsen NMOQB 1/4 whip
