I'm looking at the DB and noticed that it shows that TPD is now broadcasting in digital, 9-D for example (TG 11376) and are simulcasting to the old analog counterpart.
I just picked up a Uniden BCD996XT, which is super nice, by the way, but when I setup the system, groups, and TG ID's, I'm only picking up TPD on the old analog TG's. If I setup the system as a P25 only system, that obviously doesn't pickup anything, so following direction I've been given, I set the system up as a Type II trunked system and added the digital talk groups.
If you don't have a uniden scanner that's probably as clear as mud, but can anyone confirm that TPD is on digital now for their main dispatch TG's and if you have a uniden, did you run into the same issues?
