I decode DMR with a dongle, SDR# and dsdplus with virtual cable, using a directional beam antenna. I can decode Rogers county with no problems.
I would like to use this setup to decode NXDN in Claremore. When monitoring 460.4625 Mhz and 460.0625 Mhz, the scrolling screen indicates that I am receiving NXDN96 cs data and tb voice. However, no audio is heard.
If anyone is using this setup successfully I would appreciate knowing all the settings you use in SDR# and dsdplus.
