my uniden bc370crs for a pro-433 or pro-2051
I'm looking to trade my Uniden BC370CRS FOR A RADIO SHACK PRO-433 OR PRO-2051
HERE ARE THE SPECS. OF THE UNIDEN;
LIGHTLY USED IN EXCELLENT CONDITION
UNIDEN BEARCAT BC370CRS
WITH
S.A.M.E. WEATHER HAZARD ALERT!!!!!!!!
The Uniden Bearcat BC370CRS is your perfect bed side companion. It is a fully capable scanner covering VHF-Low Band, VHF Air Band, VHF-High Band, Military Air Band (225-380 MHz) UHF Band (406-512 MHz) and 800 Band (806-956 MHz (less cellular)). The BC370CRS features 300 scanning channels in ten banks, 10 AM and 20 FM presets, and an alarm clock. It includes coverage of all the popular scanning bands, including public safety, amateur radio, aircraft, and VHF TV broadcast. Service search allows quick access to common police, fire, ambulance, aircraft, amateur radio, and marine radio frequencies. Weather reception allows the user to instantly tune in to hear local weather conditions, forecasts, and emergency information.
What is really neat is that this scanner also features an AM and FM clock radio with snooze! The clock is even radio controlled for perfect accuracy. You can store 10 AM stations and 20 FM stations. This model also features the new "SAME" weather channel technology allowing you to scan selected counties for weather alerts.
External jacks include: BNC antenna, external speaker, AM antenna and external power. Requires three AA alkaline cells (not supplied) for backup.
The BC370CRS comes with: AD-1008 AC adapter, BNC telescopic antenna, AM loop antenna and Owner's Manual.
Size: 8.87 x 3.56 x 8.68 inches 2.51 pounds.
This space-saving scanner is also a radio that covers AM/FM and TV (audio 2-13) and includes 30 presets (10 AM, 20 FM). The BearCat BC370CRS Scanner even has an accurate atomic clock and alarm that can be set to any time zone including GMT for the radio professional. This everything radio is an excellent product that is possibly the best emergency radio you can own. Runs on included AC adapter. Requires three “AA” batteries for limited backup power only (not included).Telescopic antenna and AM loop antenna included.
Frequencies
25- 28 Citizens Band
28- 30 Ham Band 10 Meters
30- 50 VHF Low
50- 54 Ham Band 6 Meters
108-137 Aircraft
137-144 Federal Government
144-148 Ham Band 2 Meters
148-174 VHF High Band
225-380 Military Aircraft
406-420 Federal Government
420-450 Ham Band 70 Cm
450-470 UHF Band
470-512 UHF "T" Band
806-956 800 MHz Band (less cellular)
520-1720 kHz AM Broadcast Band
88-108 MHz FM Broadcast Band
BC370CRS Specifications
FREQUENCY RANGE
Citizens Band 25.0- 27.995 MHz
Amateur Band (10 Meters) 29.0- 29.7 MHz
VHF Low Band 29.7- 50.0 MHz
Amateur Band (6 Meters) 50.0- 54.0 MHz
Aircraft Band 108-137 MHz
Military Land Mobile 137-144 MHz
Amateur Band (2 Meters) 144-148 MHz
VHF High Band 148-174 MHz
Military Aircraft Band 225-380 MHz
Federal Government 406-420 MHz
Amateur Band (70 cm) 420-450 MHz
UHF Standard Band 450-470 MHz
UHF T Band 470-512 MHz
800 Band 806-956 MHz [Less cellular]
AM Broadcast Band 520-1720 kHz
FM Broadcast Band 88-108 MHz
CHANNELS
Channels 300
Banks 10 (30 channels each)
Channel Scan Rate 70 channels per second
Scan Delay 2 Seconds
SEARCH
Normal Search Rate 75 steps per second
turbo Search Rate 225 steps per second
EXTERNAL JACKS
External Speaker Mini Jack (3.5 mm)
Power Input 10 VAC
Scanner Antenna BNC
AM Antenna Terminals
GENERAL
Audio Output Maximum 0.9 watts (max.) 8 ohms
Internal Speaker 8 Ohms 2 watt
Power Requirement AD-1008 AC Adapter [12 VDC 400ma [+]]
Antenna Telescopic antenna included
Operating Temperature 14° to 122° F (-10° to +50° C)
Size 8.2 x 3.1 x 5.8 inches 1 Lb. 6 oz. (209x81x148 mm)
