FT: Pro-99 and etrex vista GPS
I have for trade the following 2 items
The first is a Pro-99. The scanner is in good great shape and comes with antennas, battery holders, belt clip and manual. Radio has been taken care of and comes from a non-smoking environment. Radio as 16 character alpha tags and CTCSS.
The second item is a Garmin etrex vista GPS. This item was given to me after an upgrade. I have been using the GPS for about a week. The GPS works great and operates 100%. The eTrex Vista combines a base map of North and South America, with a barometric altimeter and electronic compass. The compass provides bearing information while you're standing still and the altimeter determines your precise altitude. The Vista is also designed to provide precise GPS positioning using correction data obtained from the Wide Area Augmentation System (WAAS). The eTrex Vista also boasts an internal memory capacity of 24 megabytes, which allows it to accept downloaded mapping data from Garmin's MapSource CD-ROMs, Which are also included. It also comes with DC power cord and PC programming cable. The latest firmware has been installed. The only defect this unit has is that the rubber banding that goes across the top has been ripped into. The GPS appears to be a 10-10 functionally and a 7-10 in looks. However, I do want to add that that nothing is wrong with the display.
I am looking to trade both to a BC330, BC246, Pro-97, Pro-2054, or Pro-2051
