Go Back   The RadioReference.com Forums > Classifieds > Old Classifieds Archives
Old Classifieds Archives This forum contains all old classifieds posts and threads, and will ultimately be deleted within the next month or so. Provided as a reference only.
Old 09-24-2006, 6:49 PM
Exclamation FS/FT Pro 2040 Hyperscan 800MHz Base/Mobile Scanner
I have a Pro 2040 Base/Mobile scanner for sale or trade.It is in Excellent condition and comes with AC adapter,Back of set antenna and a copy of the manual.There are no marks or scratches on this scanner and it works 100%.Email me with offers or Trades.Do not reply on board please.Thank You.Here is some features of the scanner.
Features
The Radio Shack PRO-2040 100-Channel Programmable Home Scanner lets its
owner in on all the action! This scanner gives direct access to over
31,000 exciting frequencies that include police and fire departments,
ambulance and transportation services, and amateur radio. Up to 100
scanned channels can be selected, and selections can be changed at any
time.
The secret to this scanner's ability to scan so many frequencies is its
custom-designed microprocessor--a tiny, built-in computer.
The scanner also has these features:
Hyperscan - Scans 50 channels per second.
Hypersearch - Searches through frequencies at 300 steps per
second in bands that have 5kHz steps to help find
interesting broadcasts.
Ten 10-Channel Storage - Stores 10 channels in each of 10 banks to group
Banks frequencies for easy call identification.
Data Skip - Skips data signals (non-modulated signals such as
preamble signals for pagers) during a limit or a
direct search.
Priority Channel - Checks a specified channel every 2 seconds so
important calls are not missed.
Monitor Memories - Stores up to 10 frequencies located during a
frequency search which can then be transferred
into channels.
Search Function - Searches for new and unlisted frequencies using a
designated frequency range (limit search) or
starting from a specified frequency (direct
search).
Selectable Scan/Search - Allows normal or hyper scan speed selection, and
Speeds normal, high, or hyper search speeds.
Manual or Scan Channel - Allows user to manually specify a single channel
Select or to set the scanner to automatically scan all
the stored channels.
Search Skip - Selects ups to 50 frequencies for the scanner to
skip during a limit or direct search, so unwanted
frequencies can be avoided.
Two-Second Scan Delay - Delays scanning for 2 seconds before moving to
another channel, so more replies are heard.
Weather Band Key - Scans the preprogrammed weather frequencies to
keep informed about the most current weather
conditions.
Memory Backup - Keeps the channel frequencies stored in the
scanner's memory for up to 3 days during a power
loss.
Squelch Control - Adjusts the receiver's sensitivity low enough to
receive weak signals or high enough to eliminate
receiver noise when not receiving a signal.
Lock-Out Function - Prevents selected channels from being scanned.
Backlit LCD Display - Lets user easily see the indicators on the
scanner's display, even at night.
Audio Output Jack - Allows connection of an earphone or headphones for
private listening, or an external speaker for
listening in a remote or noisy area.
Optional Antenna - Let user connect the supplied telescoping antenna
Terminals to the screw-in terminal, or an external antenna
to the BNC connector.
Optional Power Sources - Lets user power the scanner using the supplied AC
adapter or an optional DC adapter.
WARNING: To prevent fire or shock hazard, do not expose this system to
rain or moisture.
The PRO-2040 can receive these bands:
Band Modulation Frequency Range Frequency Step
10-Meter Ham Band FM 29.00 - 29.7 Mhz 5.0 kHz
VHF-Lo FM 29.7 - 50.00 MHz 5.0 kHz
6-Meter Ham Band FM 50.00 - 54.00 MHz 5.0 kHz
Aircraft AM 108 - 136.975 MHz 12.5 kHz
Government/Ham FM 137 - 148 MHz 5.0 kHz
VHF-Hi FM 148 - 174 MHz 5.0 kHz
Ham/Government FM 406 - 450 MHz 12.5 kHz
UHF-Lo FM 450 - 470 MHz 12.5 kHz
UHF-T (TV) FM 470 - 512 MHz 12.5 kHz
UHF FM 806 - 956 MHz 12.5 kHz
Old 09-24-2006, 10:04 PM
Arrow SOLD Thank You
SOLD Thank You.Please close this thread.
Old 09-25-2006, 4:32 AM
do you still have the scanner?
Old 09-25-2006, 9:57 AM
Caesar's Avatar
Send a message via ICQ to Caesar Send a message via AIM to Caesar
hehe, nope, as he posted, its gone guy
Old 09-25-2006, 1:36 PM
Yep it is sold Thanks for the interest.
Old 09-25-2006, 1:47 PM
pacrat551's Avatar
TX Admin / Moderator
Send a message via AIM to pacrat551 Send a message via Yahoo to pacrat551
Closed as requested
Aaron K Slaughter, KD5MBP
Texas Severe Storms Intercept Chase-5
Radio Technician
Texas Parks and Wildlife
