Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > Oregon Radio Discussion Forum
Oregon Radio Discussion Forum Forum for discussing Radio Information in the State of Oregon.
Old 05-27-2011, 8:23 PM
Default WCCCA Trunking Frequencies
Does anyone actually know which Freq. is for which PD/Fire/WCSO?
Old 05-27-2011, 8:42 PM
KE7JFF's Avatar
Send a message via AIM to KE7JFF Send a message via MSN to KE7JFF
All of them
Old 05-27-2011, 9:13 PM
Originally Posted by KE7JFF View Post
All of them
<-- Arn't you special!
This is what I "think" i have so far:
1: 860.7375
2: 860.2375
3: 859.7375 - MDT Traffic
4: 859.2375
5: 858.2375
6: 857.2375
7: 856.2375
8: 855.9625 - Beaverton PD
9: 855.2375
10: 854.9875
11: 853.7875 - WCSO Disp1
12: 853.5375
13: 853.4875
14: 853.2875 - ? Fire
15: 853.2375 - WCSO Disp2, ? Fire
16: 852.9625
17: 852.3375 - ? Fire
I am new to this and have a Uniden Bearcat BC355c its a nice scanner but is not a trunking scanner pretty basic, wanted to start out with something simple, will work my way up eventually.
Old 05-27-2011, 11:32 PM
Trunking systems work very differently, as the frequencies are not "assigned" that way. Unfortunately you will have a very difficult time listening on a conventional scanner.
http://www.tech-faq.com/trunking.html
Old 05-27-2011, 11:52 PM
DickH's Avatar
1: 860.7375
2: 860.2375
4: 859.2375
5: 858.2375
6: 857.2375
7: 856.2375
9: 855.2375
10: 854.9875
12: 853.5375
13: 853.4875
16: 852.9625
You will not have much luck hearing complete conversations until you get a trunking scanner. With the increase in digital systems, there are lots of inexpensive used trunking scanners available. FYI here is how a Motorola trunking system, as used by WCCCA, works.
The object of trunking is to allow many users to share a relatively few frequencies.
A trunking system is controlled by a computer. Information (data) is exchanged between the system radios and the computer on a control channel, sometimes called a data channel. It sounds like a strong buzz.
A large system can have up to 28 freqs., 4 of which may be used as control channels. The control channel may be changed once a day or as often as the programmer decides. Some scanners need only the control channels to track an entire system. Just put in the 4 Control Channels.
Each group of users (Fire, Police, etc.) is assigned TALK GROUPS. In a Motorola Type II system, the most common type, TGs are usually in 32 number steps starting with 16 and going up to 65536; 16, 48, 80 --- 4656, 4688, 4720 --- 28944, 28976, etc. System radios can have more than 100 TGs programmed into them.
After all the freqs. have been entered and it is "trunking", the Banks become SCAN LISTS where you enter the Talk Groups you want to hear.
Use the Talk Group numbers in the DEC column, not in the HEX column.
When a user pushes the talk button on his radio, data is sent to the computer. The computer chooses an unused freq. and sends that data to all the radios using the TG of the originating unit. This all happens in a fraction of a second and it happens EVERY TIME a radio is used.
EXAMPLE:
Fire Dispatch calling Engine 4 (TG 4528 on 856.7125)
Engine 4 answering Dispatch (TG 4528 on 852.2625)
Respond to 73 Elm Street (TG 4528 on 855.9625)
Engine 4 responding (TG 4528 on 851.6375)
If you have entered TG 4528 into your scanner, it will decode the control channel data and change your scanner freqs. to follow the conversation on TG 4528.
Dick H
http://dickh.zenfolio.com
Old 05-28-2011, 2:36 AM
PMJ2kx's Avatar
Database entry with talkgroups and info
Washington County / Clackamas County / Newberg Trunking System, Various, Oregon - Scanner Frequencies
Wiki pages you may be interested in:
Washington County (OR) - The RadioReference Wiki
Washington County / Clackamas County / Newberg - The RadioReference Wiki
Joint CAD Incident Tracking System - The RadioReference Wiki
List of Washington County Stations/Units - The RadioReference Wiki
Welcome to the RadioReference Forums!
BCD396XT | BC246T | BC92XLT
Watson W-881 | RS 20-032 | RS 20-176
Old 05-28-2011, 2:39 AM
Thank you guys very much, I've learned alot.. now I want a trunk tracking scanner giggle...
Old 05-28-2011, 6:32 PM
DickH's Avatar
There is a complication that has not been mentioned - RE-BANDING.
Because of conflictions with other services on the 800 band, some Public Safety freqs. were
changed and older trunking scanners can not follow conversations on systems using the new freqs. The Portland system was not affected, but WCCCA & Clackamas have a few of the trouble freqs. Older trunking scanners can follow most of those conversations, but newer scanners have the "fix" built in so you can hear everything. Ask about a specific scanner model before buying and someone here should be able to advise you..
Dick H
Old 05-28-2011, 6:36 PM
DickH's Avatar
By the way, KE7JFF's reply was 100% correct. You will hear any agency on any of the trunking system freqs. Freqs. are not specific to any agency in a trunking system.
Dick H
