| Oregon Radio Discussion Forum Forum for discussing Radio Information in the State of Oregon. |
01-15-2013, 10:29 PM
This afternoon, I heard testing on Albany PD P25 talkgroups 22033 and 22035.
However, no other info was transmitted, such as usage or channel.
Has anyone else heard this?
Additionally, talkgroup 22031 Albany PD Dispatch is using 773.45625 as a control channel, according to my GRECOM PSR-800.
01-16-2013, 6:14 PM
Originally Posted by OregonScanner
I think there was an error made to the Clackamas County/Washington County page. Mike PDX said that 64592 Clackamas County Sheriff Detectives Admin was C-COM Law Tac 3. However, Washington County Sheriff talkgroup 63952 was changed to WCSO Tac 3. I think this was done on accident since 64592 still says Clackamas Co SO Detectives Admin. Can anyone else comment?
I agree.
01-16-2013, 10:51 PM
My records show that 63952 is Washington County Sheriff Detectives?
01-16-2013, 11:01 PM
Possibly, I'm not sure what it used to be. I don't think it was in the db before it was updated recently. I was agreeing with you that it had been mistakenly added as WCSO TAC 3. Actually I do see now that it was WCSO Detectives F4. I think those were removed long ago though.
Sent from my DROID BIONIC
03-08-2013, 5:55 PM
Under Benton County, the PL tone for Good Samaritan Regional Medical Center (GSRMC) is 167.9. This is confirmed by my scanner (GRE PSR-800) and via email from Bryan Anderson, via Chief Andy Louden, both of whom are with the Corvallis Fire Dept.
Please add to the database.
73,
Richard, NW7OR
03-08-2013, 9:46 PM
I should have mentioned that the only frequency used by GSRMC to communicate with the ambulances is 155.34 MHz. The officials mentioned above also confirmed this.
I apologize for the omission.
73,
Richard, NW7OR
03-10-2013, 1:47 PM
DB Admin Member
Ok a bit more info is needed here on my part. so you want to add 155.34 with a PL 167.9 right ??? and what city does it need to belong in.
03-10-2013, 5:30 PM
The Corvallis Fire Dept. is located in Corvallis, Oregon.
I apologize for any misunderstanding.
73,
Richard, NW7OR
03-16-2013, 3:51 PM
DB Admin Member
Sorry about the delay, but I have added that info.
03-16-2013, 5:46 PM
Many thanks....
73,
Richard, NW7OR
03-16-2013, 7:12 PM
DB Admin Member
Many thanks....
73,
Richard, NW7OR
Sure thing
03-17-2013, 12:57 AM
Is there any chance of this being added under "Benton, County of" as well?
Benton County, Oregon (OR) Scanner Frequencies and Radio Frequency Reference
After all, all of the ambulances use this frequency and PL tone to communicate with the hospital.
Additionally, this would make the database listing consistent with how the hospitals are listed under "Linn, County of".
Linn County, Oregon (OR) Scanner Frequencies and Radio Frequency Reference
Many thanks...............
73,
Richard, NW7OR
03-18-2013, 2:02 PM
The following three frequencies need to be deleted from the Washington County section, as they have either been re-purposed for data or are now part of Nextel Holdings.
Code:
858.68750 WPEJ994 RM 156.7 PL FTac2Lookout Fire Tactical 2 (Lookout) FM Fire-Tac
851.76250 WNSK475 RM 192.8 PL RTOP1 Sheriff Dispatch 1 (Round Top) FM Law Dispatch
855.73750 WNSK475 RM 192.8 PL BUX1 Sheriff Dispatch 1 (Buxton) FM Law Dispatch
BC346XT | BCD396XT | BC246T | BC92XLT
Watson W-881 | RS 20-032 | RS 20-176
03-18-2013, 4:27 PM
Code:
851.7625 is not licensed in Oregon
855.7375 & 858.6875 were newly licensed 6 days ago to Washington county.
Look up WQQV747.
03-19-2013, 12:25 AM
Look up WQQV747.
851.7625 is not licensed to any public safety agency in Oregon - but it does show up on eight different Nextel licenses across the state. Either way, it doesn't need to be in there any longer.
As for WQQV747, if you look at the emission designators, you'll see 17K7D7D and 20K0F1D. Also, if you check the original application, you'll see this is part of the Motorola RD LAP 19.2 Data Tac system (MDTs), not part of the 16 channel simulcast system, nor are they used as conventional frequencies on the west end, as that has been eliminated due to the West Simulcast site working well to fill in coverage gaps.
I can find Joe Kuran's paperwork regarding this, if you would like me to verify it for you.
Reason: I am "hit-enter-too-soon" man
03-22-2013, 5:35 AM
DB Admin Member
Code:
Done
03-23-2013, 4:05 PM
DB Admin Member
It is under Benton County under business where it should be unless it's is owned by the County and operated by the County, Linn County needs to be changed.
03-24-2013, 12:05 AM
Actually...if you really want to get technical, 155.340Mhz is a statewide "interop" ambulance-to-hospital channel (HEARS), falling under the blanket statewide license WPKA928, so it should (and currently is) listed under statewide Common/Shared frequencies.
But that's only if you want to get technical.
03-24-2013, 9:13 AM
Well, I do see your point, however, I my suggestion is based on the fact that 155.34 MHz is a public safety band frequency and the ambulances are owned by the respective fire departments and, therefore, should be listed as such in the database.
I would also suggest that a hospital's business band frequencies (e.g. grounds keeping, housekeeping, maintenance, etc.) be listed as such under the business section as appropriate.
Just suggesting is all.
73,
Richard, NW7OR
