Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > Oregon Radio Discussion Forum
Oregon Radio Discussion Forum Forum for discussing Radio Information in the State of Oregon.
Old 10-23-2012, 12:17 AM
Question Tri-Met Trunking
I am hoping someone can help me with listening to Max Light Rail. I have downloaded both the frequencies and ids per Radio Reference.com. I know that my scanner,RS Pro 106 Digital has been uploaded properly as I can download with WIN 500 A-OK. I stayed in Portland three days with the scanner on for hours several days and nothing heard, no signal, no nothing. Could hear UP , Amtrak & BNSF, NO "Max"
Would very much appreciate help/input! 73's N7ENE
Old 10-23-2012, 8:10 PM
Since joescanner is pretty busy...
MAX Light Rail currently (but will change I think next year) is on the Portland Public Safety Radio System Trunking System, Portland, Multi-State - Scanner Frequencies system with police and lots of others, so try setting the bank to open/search mode and see if you can hear anything.
The control channel frequency I'm currently getting is 859.46250
Old 10-23-2012, 9:24 PM
DickH's Avatar
Try these talk groups:
27824 Tri-Met (MAX) Rail Maintenance West
27856 Tri-Met (BUS) Operations Tac 3
27888 Tri-Met (ICS) Incident Command
27920 Tri-Met (BUS) Special Events
27952 Tri-Met (SAT) Customer Service
27984 Tri-Met (MAX) Rail Maintenance North
28016 Tri-Met (MAX) Tunnel
28048 Tri-Met (MAX) Rail Maintenance Tac 1
28080 Tri-Met (MAX) Fare Maintenance Tactical
28112 Tri-Met (FIO) Fare Inspection
28144 Tri-Met (MAX) Rail Maintenance East
28176 Tri-Met (MAX) Elmonica Rail Yard
28208 Tri-Met (MAX) Main 1 E.Light Rail Dispatch
28240 Tri-Met (MAX) Main 2 W. Light Rail Dispatch
28272 Tri-Met (MAX) Main 3 Administration
28304 Tri-Met (MAX) Ruby Junction Rail Yard
28336 Tri-Met (MAX) Rail Ch 6 (RL SUP/RL TAC 1)
28368 Tri-Met (MAX) Rail Ch 7 (RL TAC/RL TAC 2)
28400 Tri-Met (MAX) Rail Maintenance Tac 2
28432 Tri-Met (BUS) BUS Supervisors / Dispatch
28464 Tri-Met (SEC) Security BUST1
28496 Tri-Met (BUS) Operations Tac 2
28560 Tri-Met Announcement Talkgroup
38416 Streetcar Main
38448 Streetcar Tac 1
38480 Streetcar Tac 2
Dick H
http://dickh.zenfolio.com
Old 10-23-2012, 9:57 PM
DickH's Avatar
Here are 3 more I found.
28624 TRIMET ICS 2
28656 TRIMET ICS 3
28688 TRIMET C6
Dick H
Old 10-23-2012, 10:57 PM
Your list is out of date. Instead of "Main x" it's now East, Central, CBD and West (the DB has the correct info)
Old 10-24-2012, 8:21 AM
DickH's Avatar
That's entirely possible since I don't have any interest in Tri-Met TGs.
Dick H
