Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > Oregon Radio Discussion Forum
Oregon Radio Discussion Forum Forum for discussing Radio Information in the State of Oregon.
Old 07-25-2013, 6:28 PM
Default been a long time !
hey everybody , decided to get back into scanning and was wondering what are the control channels i need for portland ,clakamas,gresham,, i looked on the website here , but there are a ton of control channels , which ones am i suppose to use ? thanks
Old 07-25-2013, 8:38 PM
Usually just the primary ones for the simulcast backbone; some of the other sites are gap fillers and only broadcast what's needed for the radios currently affiliated with them
Old 07-26-2013, 1:54 AM
thanks for the reply , so i should use : 858.7125, 858.7375, 859.2625 ,859.4625 ??
the stuff i want to listen too is portland police,port. fire , mult. ems,clack. fire/sheriff,gresham/fairview pd/fd,odot,federal,pdx airport,forest service , etc, , i have the butel software for my pro-162
Old 07-26-2013, 3:28 AM
That should work for most of the Multnomah County stuff (and only one of the frequencies is usually active, but I don't think it hurts to program the others).
For Clackamas County, try the frequencies on this page: Clackamas County, Oregon (OR) or some of the control channels on this page: Washington County / Clackamas County / Newberg (I'm not sure which ones exactly; it might depend on where you are).
Old 07-26-2013, 9:36 AM
joescanner's Avatar
Just another radio geek.
I'm going to get a lot of negative feedback on what I am about to post, but to track Clackamas County properly, you need at least the first two lines of the custom bandplan below.
I don't know how this gets entered in the pro-162 (or whichever programming software you might be using). The format is frequency, spacing, channel number. (If your scanner can accomodate all of the entries it will work for both rebanded and non-rebanded systems).
Bandplan Range #1 = 851.0125 25.0 0
Bandplan Range #2 = 851.0250 25.0 440
Bandplan Range #3 = 865.0125 25.0 560
Bandplan Range #4 = 866.0000 25.0 720
Bandplan Range #5 = 867.0000 25.0 815
Bandplan Range #6 = 868.9750 25.0 958
Bandplan Range #7 = 867.4250 25.0 961
Joseph Stein, KD7MLG
Old 07-26-2013, 10:45 AM
DickH's Avatar
Yes, those are the correct control channels.
If you want to monitor the Clackamas County system the 4 control channels are:
852.43750, 852.86250, 853.26250, 853.76250
The PRO-162 needs 2 Custom Band Plans for Clackamas County. All the info. is in the scanners menu. Below are the steps you need to follow.
TO SET BAND PLAN 1:
After each step, except 1., push ENT/PGM
1 Push FUNC, then MAN/MENU
2 Select TRUNK OPTION ENT/PGM
3 Select BANK ENT/PGM
4 Select MOTOROLA ENT/PGM
5 Select 800MHz CH PLAN ENT/PGM
6 Select CUSTOM ENT/PGM
7 Select CUSTOM RANGE 1 ENT/PGM
8 Select BASE FREQ ENT/PGM
9 Enter 851.0125 ENT/PGM
10 Enter 854.0000 ENT/PGM
11 Select OFFSET ENT/PGM
12 Enter 0 ENT/PGM
13 Select SPACING ENT/PGM
14 Select 25.0 kHz ENT/PGM
15 Push CL
TO SET BAND PLAN 2:
2 TRUNK OPTION ENT/PGM
7 Select CUSTOM RANGE 2 ENT/PGM
9 Enter 851.0250 ENT/PGM
10 Enter854.0000 ENT/PGM
12 Enter 440 ENT/PGM
15 Push CL
16 Push SCAN
Now it will start trunking in the OPEN mode. (+ beside T on the top line).
To change to CLOSED mode push FUNC, then OPEN/CLOSE. (- beside T on the top line).
Dick H
http://dickh.zenfolio.com
Old 07-27-2013, 12:59 AM
wow ! thank you for all the help everybody !!! i appreciate it !
Copyright ©2000 - 2015, vBulletin Solutions, Inc.
