Please Discuss the Proposed Berks County 700/800mhz Digital Trunk System here:
CommJunkie said:The report says that T-Band is not recommended due to distance from Philadelphia. I have no idea what that's supposed to mean. Does that mean they won't be able to get licenses for those frequencies?
Steveradio said:Don't forget about Northampton County using 500Mhz or T-band frequencies.
I always thought that the UHF T-Band was in regions and the 500 - 512Mhz range was for Philadelphia Region the 470 - 480Mhz New York Metro could be wrong but remember seeing it in a back issue of POLICE CALL one time?
Steve
Yeah It would be nice if bucks went to 800 since Montco is on that.
what is the problem with low band and high band that they would need to change it to 700/800 mhz
The UHF-T band is standard (470-512). It's availability for public safety usage changes between regions, based on which TV channels are being used for TV broadcast in those regions. Most major metropolitan centers have between 2 and 10 major TV broadcast stations in use. But an analog TV broadcast takes up quite a chunk of frequency (called bandwidth). This is part of the reason for the analog-digital TV broadcast deadline; once all TV stations are operating in digital mode, each station will use a considerably smaller amount of bandwidth, freeing up additional frequency space for land mobile users.
