I am stumped. I am trying to monitor Bucks County on a BC785D and I cant figure it out. I have all the data programmed as best as I can figure, however, I am receiving all system transmissions (cops and everything), whereas I just want to monitor fire talkgroups.
Help!
Ok, I'm not too familiar with the Unidens, but I'll give it a shot. From what I read in the manual for your scanner (
Link here)
- ID SCAN recieves only talkgroups that you have programmed into the scanner
- SEARCH mode will recieve all talkgroups on the system (like "open" mode on the Pro-96
You should be able to lock out what you don't want using either mode, or you can only program the fire Talkgroups into the bank (may be easier since there are only 5 Fire TGs on the system)
- 464 - Fire North
- 496 - Fire South
- 528 - Fire West
- 560 - Fire East
- 592 - Fire Emergency
The good news is that you're hearing anything at all, Bucks has a custom table which can be a pain in the you-know-where. :lol:
Hope this helps!
Oh, you may want to start saving the pennies for a newer scanner. According to this
Article (taken from the announcements forum) Bucks will be narrowbanding within the next 4 years or so.
