Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > Pennsylvania Radio Discussion Forum
Pennsylvania Radio Discussion Forum Forum for discussing Radio Information in the State of Pennsylvania.
  #201 (permalink)
Old 01-17-2013, 9:09 AM
PFD just announced "cutover is complete. All fire department ops will now be on new system."
FYI South Division Police cuts over tomorrow, 1-18-13.
  #202 (permalink)
Old 01-17-2013, 11:52 AM
So, PhillyFireNews has a consolidated post explaining what's up:
http://pafirenews.net/messageboard/i...54381#msg54381
Anyone using a 396XT on the new system? I'd like to be able to listen without dropping money on another scanner.
Sent from my mobile device using Tapatalk. Note that I still a managed to spell most things right and use proper grammar? You can too!
  #203 (permalink)
Old 01-17-2013, 11:56 AM
W2GLD's Avatar
Send a message via AIM to W2GLD
The Uniden BCD396T/996T and the BCD396XT/996XT all work just fine with this system for now; whomever wrote the article on PhillyFireNews.com apparently did not do their comprehensive homework...
When Phase 2 talkgroups begin showing up on the system, those will only work on the PSR-800 scanner at the present time!
Philadelphia New Radio System
Current Station Equipment:
| Uniden BC125AT, BCD-396XT, & BCD-996XT | GRE PSR-500 & PSR-600 |
| ICOM iDAS (NXDN) Portables - Mobiles - Repeaters |
  #204 (permalink)
Old 01-17-2013, 12:01 PM
Wirelessly posted (Mozilla/5.0 (Linux; U; Android 2.3.5; en-us; ZTE-N910 Build/GRJ90) AppleWebKit/533.1 (KHTML, like Gecko) Version/4.0 Mobile Safari/533.1)
I think that is just a typo on the pfn site. I have been in contact with the owner of the site regarding the new system, so he has gotten acurate info from me. I will advise him of the error
Scanning Philly, Bucks, Eastern MontCo, & DelCo Fire.
Base radios: TK-7180 VHF, TK-8180 UHF, CDM-750 VHF, Pro-197, PSR-800
Mobile radios: NX-700 VHF, NX-800 UHF, Pro-96, & Wouxun HT.
  #205 (permalink)
Old 01-17-2013, 7:41 PM
I've got the new systems plugged into my BC396T as well as the 996T in the car. So far driving through the city, reception seems to be much improved on the 996T, much less chopping of signal etc. Don't have enough technical knowledge to know if this is due to improvements made to the system, or the scanner itself, or what.
Dave
  #206 (permalink)
Old 01-17-2013, 8:20 PM
I still think I'm gonna go with an external antenna for in the car. The 396 and 996 might have slightly better receivers than the PSR-800
  #207 (permalink)
Old 01-17-2013, 8:23 PM
I have mine hooked up to a larsen cell lookalike glass mount scanner antenna tuned for 800mhz. Wasn't about to drill any holes...
  #208 (permalink)
Old 01-17-2013, 8:25 PM
I have an 800 Mhz high-gain whip I can put on my trunk lip mount. Just have to actually get off my butt and do it lol.
  #209 (permalink)
Old 01-17-2013, 9:57 PM
Hi, I imported RR freq's into my RS pro-2096, set system to mot, and set 3600 baud to normal and 9600 to normal, works fine, signal strength is down but works. 73
  #210 (permalink)
Old 01-17-2013, 11:37 PM
Smile Pro-96 on Phillys new system:
I programmed the two new 9600 baud controll channels in my pro-96. The display was showing the controll channels and the new talk group numbers. No voice was heard. I had my pro-106 on also and it worked just fine. I have it set to p-25 auto. The 106 was getting audio and I was able to hear the radio traffic. It displayed the CC, voice channel freq, radio number, and motorola channel number. I then noticed why the pro-96 was not picking-up any voice traffic.It was going to the wrong voice channel. While listening to the same talk group on both radios, the pro-106 showed the voice channel 852.1625. The pro-96 showed the voice channel 855.2125. Wrong voice channel ! This is why the pro-96 is silent ! What is the solution to this problem? Custom tables? If so, what is the base,off-set,and step? No spot for high/low freqs. Let me know. Thanks. Plato.
David E. Richman
  #211 (permalink)
Old 01-18-2013, 12:07 AM
Danny6569's Avatar
Red face Philadelpia
Ok can anyone tell me how to manually set up this system for my 396 xt ? such as would it start as a p-25 system or an mot system or what? and what band plan should i use? 800/900 standard or splinter ? and what band plan frequencies and off sets and etc...? Anyone?
Daniel
  #212 (permalink)
Old 01-18-2013, 5:33 AM
Danny, you should set it to P25 system with no special tables, and it should work.
  #213 (permalink)
Old 01-18-2013, 6:37 AM
Septa3371CSX1's Avatar
Send a message via AIM to Septa3371CSX1 Send a message via Yahoo to Septa3371CSX1
Looks like everything is on the new system as of now. Been monitoring the old system for about 10 minutes now and no activity.
Joe Butler
Scanning the Delaware Valley with a Pro 164, a Pro 106, and a Pro 2055!
Septa3371CSX1@aol.com
Victory5318@gmail.com
  #214 (permalink)
Old 01-18-2013, 7:19 AM
I need to upgrade firmware on 996XT....has anyone needed to make adjustments to the "hidden" P25 Adjust Mode or level...the upgrade suggests Mode setting of 11 (or 8) and level 50
  #215 (permalink)
Old 01-18-2013, 8:55 AM
soberbyker's Avatar
Send a message via AIM to soberbyker
Yep, 1/3/17 & 22nd on the new system now, still haven't heard an M band broadcast though.
So what do you guys think, sound quality the same, better worse? I have a Pro-197 on my desk, it's connected to a magnetic mobile antenna which sits outside my 2nd floor window on the sill, neither have moved in months, the new system for me is pretty much the same leaning toward louder but a tad choppier.
Realistic Pro-2022, RS Pro-197, Beltronics Pro500, Cobra 75 WX ST, PC78 Elite, PC68LTW
  #216 (permalink)
Old 01-18-2013, 9:48 AM
Theo's Avatar
Wirelessly posted (Mozilla/5.0 (iPhone; CPU iPhone OS 6_0_2 like Mac OS X) AppleWebKit/536.26 (KHTML, like Gecko) Version/6.0 Mobile/10A551 Safari/8536.25)
Need some help programming the 396,996t's. right from step one would help. All frequencies or just control channels, and all the other settings. Using ARC software. Tried several different ways no luck.
  #217 (permalink)
Old 01-18-2013, 10:48 AM
M Band won't be on line until 1-19-13 or so.
Mobile reception is extremely poor, very choppy with a RS Pro106 smack in the middle of the city.
  #218 (permalink)
Old 01-18-2013, 10:50 AM
rgchristy's Avatar
One thing i noticed on my way to work is that the usual dead spots on the old system are even worse on the new system. Looks like my PSR-800 is going to get a trunk mounted antenna shortly along with an amplified speaker.
That's my problem, too. I live on Beatty Rd. in Springfield and as soon as I get over the hill coming from 320 towards the Blue Route, I lose the system. I was able to pick up the old system fine. I'm getting ready to reprogram my PSR-500 to see if it makes a difference.
Take Care,
Rich C
  #219 (permalink)
Old 01-18-2013, 10:54 AM
rgchristy's Avatar
I also monitor the PhillyScanner Yahoo group and I noticed that they keep mentioning that Philly has rebanded. I could be wrong, but I thought that this was a new system and that they cut over to it.
As far as listening to the new system, when I'm in the car, the system sounds louder and the audio appears to be clearer. Just my $.02
Take Care,
Rich C
  #220 (permalink)
Old 01-18-2013, 11:06 AM
They switched from 3600 baud to 9600 baud.
Same towers and infrastructure, rebanded frequencies, FD got new portable radios, PD has mix of XTS3000 and new XTS5000. Basically an upgrade.
