Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > Pennsylvania Radio Discussion Forum
Pennsylvania Radio Discussion Forum Forum for discussing Radio Information in the State of Pennsylvania.
Old 11-18-2012, 12:52 PM
Default Lafayette College Security Now Digital?
I visted Lafayette College in Easton this weekend for Lehigh-Lafayette football and after the game while listening to the scanner I noted that the college security frequency of 461.375 dcs025 was strangely silent. I cancelled the dcs and also did close call searching and found strong signal digital transmissions on 461.375. My Uniden 396XT could not decode the digital signal. I hadn't tried to get a look at the security radios while I was at the college earlier, but in retrospect I believe one of the officers I saw in the distance had a keypad-equiped radio. My suspicion is that they have gone to a MotoTRBO system.
I don't know whether they upgraded just because someone wanted a new toy or perhaps more likely because students with medical emergencies and those charged with violations commonly had their names broadcast over the analog radios. I will try to get a look at a radio next time I am down there. College maintenance communications were still analog on their 464.425 repeater.
Mark S
Old 11-18-2012, 2:20 PM
benrussellpa's Avatar
Pennsylvania DB Admin
Their FCC license now shows 7K60FXE for an emission designator. This would be TRBO. Another one bites the dust.
Old 11-18-2012, 5:33 PM
Thanks for the prompt comment. Also, thanks for the info on emission designator in the license. I hadn't been aware of them before.
Old 11-18-2012, 9:35 PM
No problem. Thanks for finding the change in use.
A long list of emission designators can be found here:
Emission Designator - The RadioReference Wiki
What's the PL for the maintenance repeater?
Old 11-20-2012, 10:57 AM
Does this mean I will or not be able to hear the active anymore?? I have the frequencies in my scanner and the scanner I have is BCD996XT
Old 11-20-2012, 11:27 AM
lep's Avatar
lep lep is offline
I don't live in your area but I do have a bCD996XT and it will not decode MOTRBO as it stands.
Old 11-29-2012, 6:06 AM
To answer the above questions:
1. If you monitor Lafayette Security with the 996XT you will here a digital annoying "motorboating" sound when they transmit.
2. The Lafayette maintenance repeater on 464.425 uses DCS754.
I will check on my periodic visits to campus to see if maintenance makes the switch to TRBO.
Mark S
Old 01-30-2013, 9:20 PM
Steveradio's Avatar
Have a feeling that Northampton College also did the same, local radio shop has been pushing smart radio network portable xpr6550 depends on system $20 per month per radio so its possible they are.
http://lvcomm.proboards33.com/index.cgi
Scanning Lehigh Valley, Pa. North of Philadelphia
