Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > Pennsylvania Radio Discussion Forum
Pennsylvania Radio Discussion Forum Forum for discussing Radio Information in the State of Pennsylvania.
  #21 (permalink)
Old 03-04-2013, 5:25 PM
fire42man's Avatar
Originally Posted by kirkwoodcr View Post
If anything, there is another agency using 155.22 with a PL 82.5 which is the old EMS channel. Maybe you're hearing that.
Yes, the frequency is also being used by two nearby counties, Brooke WV and Armstrong PA, both with the same PL of 82.5. However, I was referring to the new frequency about the signal.
PRO-163, BC72XLT, BC760XLT x3, Plectron R719 x2, Kenwood TH-78A, Cobra 19 Ultra III - My growing fleet of radios
One of the biggest wackers in Western PA
  #22 (permalink)
Old 03-04-2013, 7:02 PM
154.340 is nice and strong in the South Hills. I also get Mon Valley EMS with PL 91.5 here, but is a bit weaker. Is 154.340 a temporary stay? I suspect not since they seem to have the tones programmed on this freq.
Frank K3FS
http://www.pghscanner.com
  #23 (permalink)
Old 03-05-2013, 7:27 AM
Ah ok, I have no problems getting the repeater signal.
I did find out the PL 82.5 is Armstrong county's EMS.
  #24 (permalink)
Old 03-07-2013, 8:17 AM
Funny enough, I'm even picking up Indiana county EMS at PL 114.8 on the old BvCo EMS channel
  #25 (permalink)
Old 03-07-2013, 2:46 PM
Slightly off topic and for that I apologize...
Could somebody let me know if these 3 fire companies are still operational in Beaver County:
27 - Freedom Volunteer Fire Department
29 - South Side Volunteer Fire Department of Rochester
45 - South Heights Volunteer Fire Company
Thank you.
Jason I. Faryniak, Firefighter/Paramedic
Monitoring PA with a HomePatrol-1, a BC396XT, a BC780XLT, a BC8500XLT, a BC246T, 2 BC350As, an IC-PCR100 and in "reserve" a BC100 and Bearcat 201.
  #26 (permalink)
Old 03-09-2013, 8:36 AM
Thank you.
I do not think so, South Heights for sure is not. Freedom uses Pine Run.
  #27 (permalink)
Old 03-13-2013, 5:38 PM
jlinko's Avatar
Default Changes in channel assignments?
This morning hearing EMS traffic on the Fire Tac B, 154.340 PL 186.2. Per the most recent county newsletter there was an advisory that the freq would be changing. Unknown if 155.220 will be used for anything else, but wasn't hearing anything on it this morning, simulcast or otherwise.
Perhaps if anyone has access to revised list of frequencies and assignments...thanks much.
  #28 (permalink)
Old 03-14-2013, 2:26 PM
If anything, they may change 155.22 to an EMS ops channel.
As for a list, they're rehasing most of their existing, aside from adding input frequencies.
  #29 (permalink)
Old 04-02-2013, 2:15 PM
Old Zn 2 is being tested for Fire ops - 155.61 88.5 PL
Also, Fire Response 1 is going through repeater testing - 155.7225 PL 103.5
  #30 (permalink)
Old 04-08-2013, 7:00 PM
A lot of testing today.
TAC A has a new PL 91.5 154.295
153.4175 running PL 88.5 is testing for Fire Ops (It's labled as Brighton DPW2) This is Fire Response Ch 13
TAC C is running DPL 155 was also testing
The old Zn 2 PD 155.610 running PL 88.5 was testing as Ch 3.
Tags
beaver county, radio system upgrade
