Originally Posted by kd3yt1
When I tried to import the freq files from RR, their was nothing for Blair County - Guess it is too new.
The new info is there, and should have downloaded. Maybe you went into the trunking systems sections. It is conventional P-25. I would try to import again, but select conventional.
2. How do I either use ARC500 or manually program the scanner ( I have not problem trying
to manually doing it).
I don't have a PRS500, but the basic answer is however you program conventional frequencies, you do it the same way, For Unidens, you have to change the audio from analog to digital for each P-25 freq, but I did not find that option in ARC500, so it may auto detect P-25.
Here's a guide:
http://wiki.radioreference.com/index...500_User_Guide
