Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > Pennsylvania Radio Discussion Forum
Pennsylvania Radio Discussion Forum Forum for discussing Radio Information in the State of Pennsylvania.
Old 01-29-2013, 8:15 PM
Default hello from schuylkill county
what scanner codes will allow me to listen to everything in the county? i am forced to use the app bc i believe i am missing some.... thanks in advance
Old 01-30-2013, 2:10 AM
Steveradio's Avatar
well depends on where you live in Schuylkill Co they operate off alot of different towers because of the hills and valleys. Used live in Tamaqua and hearing the rest of the county unless had external antenna.. Fire is 46.5800mhz for that area and didnt work that great when ran with fire dept. Everything on RR Database is correct you just need to play around with placing your scanner in right location..
http://lvcomm.proboards33.com/index.cgi
Scanning Lehigh Valley, Pa. North of Philadelphia
Old 01-30-2013, 7:10 AM
Here is the link to the database for your county. Schuylkill County, Pennsylvania (PA) Scanner Frequencies and Radio Frequency Reference
Dave
My Scanners: Uniden Bearcat BC355N, Uniden Bearcat BC125AT, RadioShack PRO-2014, Bearcat 210XL
