Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > Pennsylvania Radio Discussion Forum
Pennsylvania Radio Discussion Forum Forum for discussing Radio Information in the State of Pennsylvania.
Old 02-01-2013, 6:42 PM
Default How to program psr800
Seriously, I cant figure this out. scanlists, and all this new crap is so confusing.
This isnt "EZ" at all, and I've tried using the database on the software, it just lists the old frequencies.
Old 02-01-2013, 7:24 PM
bgav's Avatar
Object Oriented Scanning Described - The RadioReference Wiki
http://www.greamerica.com/support/in...oaditemid=1028
HP-1|PSR-800|BC780XLT|Pro-92
PlanePlotter Ground Station ya
Old 02-01-2013, 10:32 PM
Would you mind explaining to me how to enter a frequency(I was going to use the control frequencies listed for philly) as an "object" so that I can scan it.
I am literally getting nothing right now.
Old 02-01-2013, 10:53 PM
When I press scan, or "SEL" I can see that it is scanning, but absolutely nothing is coming from the speaker. I know it's gotta be one small little thing im over looking, but god damned if I cant find it. please help me, someone, i just spent $400 on this damn thing.
Old 02-02-2013, 6:08 AM
Send a message via Yahoo to trap5858
Take a look on Youtube- enter PSR-800 for some great "how to" videos. You will need to get into the library stored on the SD card to select your objects for scanning.
Old 02-02-2013, 8:12 AM
troymail's Avatar
Assuming you are trying to load and listen to the Philly system for police and fire, it appears they are using the latest technology (P25 Phase 2).
Have you installed all of the radio's CPU and DSP updates via the EZ Scan software?
If not - we can help.
If I'm off track, provide a bit more info and we'll try to help!
Top suggestion: patience.
Future PSR-900 user...(still hoping!)
PSR-800 x 2 | PSR-500
BCD-396T | BC-296D (voice) | BC-245XLT (mTrunker) | BC-600XLT | BC-IV | VX-8R
Not a Radio Shack fan.....
Old 02-02-2013, 11:54 AM
Listen, I've already read the manual, watched countless youtube videos, and searched a lot. They aren't helping.
I just updated my cpu and dsp. They are completed, but still nothing.
I have the right frequencies added to my scan list, with a wild card as a talkgroup, so I should get something. The signal bars are about 3 to 4, but still nothing. I just dont understand what I'm doing wrong.
Old 02-02-2013, 12:04 PM
troymail's Avatar
Is this the system you are having problems with?
Philadelphia (Project 25) Trunking System, Philadelphia, Pennsylvania - Scanner Frequencies
Newer systems like this are fairly hard to receive. They can be hard to receive in the area they are intended for and even harder it you are outside the area.
You probably already know that the PSR800 is the only one with the ability to really receive it since it's a "Phase 2" system.
Are you inside Philadelphia?
Are you seeing the [T] trunking icon on the PSR800 display?
If so, is it steady with an occasional blink or rarely or never there?
Old 02-02-2013, 12:48 PM
I live inside philadelphia, and there is a repeater(or site) about 2 miles from my house. But no, there is no T icon. I am trying to recieve just police, specifically the 2nd and 15th districts, I have put a wildcard in as my talkgroup just so I can get something.
This is how I have it configured, then I select this "object" and press select. then it gives me this screen.
Old 02-02-2013, 12:54 PM
troymail's Avatar
jessek14 - I just sent you a PM --
Old 02-02-2013, 12:59 PM
troymail's Avatar
You really shouldn't need to MANUALLY program the system -- you should import it from the PSR800 library.
You can do that from within EZ Scan and then copy it to your radio -or- import it directly from the SD card using the menu options on the radio itself.
Old 02-02-2013, 5:39 PM
I was able to get it to work, after receiving a custom made v card file by a member here. It is working perfectly now, and I am very appreciative of all the help here.
