Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > Pennsylvania Radio Discussion Forum
Pennsylvania Radio Discussion Forum Forum for discussing Radio Information in the State of Pennsylvania.
Old 03-04-2013, 7:57 AM
Default Frequency ID
I came across a frequency while searching and need some help ID'ing it. It is 460.375 with a PL of 203.5. I did a search within 50 miles of the Harrisburg area (where I work) and only came up with Pennsylvania, Commonwealth of...
Does anyone have any additional information as to what agency that might be?
Dave
My Scanners: Uniden Bearcat BC355N, Uniden Bearcat BC125AT, RadioShack PRO-2014, Bearcat 210XL
Old 03-04-2013, 8:11 AM
RonnieUSA's Avatar
Maybe one of these.
460.37500 465.37500 203.5 PL KXM868 County Police Dispatch Old County Police/Fire/EMS
Bedford County Bedford
PA
460.37500 465.37500 203.5 PL WPAD607 Southwest Regional Police Law Enforcement
Mercer County Mercer
PA
Radio Shack Pro-197 - Uniden BCT15X
Win500 - ARC500 - FreeScan - ARC-XT-PRO - ID Tracker III
Old 03-04-2013, 9:33 AM
captclint's Avatar
Mentor
Originally Posted by RonnieUSA View Post
Maybe one of these.
Not very helpful. Both are 100's of miles from Harrisburg. Since no one has entered the PL for this entry http://www.radioreference.com/apps/d...llsign=KA93574 in the database, it is possible that is what you are hearing. Since there is another freq using that PL (http://www.radioreference.com/apps/d...=2262#cid-8064) it is quite likely that this is it. If you determine that is it, by listening(Harrisburg Farm Show Complex), then please submit the PL to the database so others will be able to tell what it is by a search of the DB, which you could do if you were a member.
Regards,
Clint Chamberlin
Luzerne County, PA
Old 03-04-2013, 9:44 AM
Thanks, Ronnie. As captclint said, not much chance of me picking those up on a portable with the rubber ducky antenna. Thanks though.
captclint, that could be. I'm not a premium member (need to change that), so I couldn't check in here. I used the FCC license search.
Dave
Old 03-04-2013, 12:36 PM
Send a message via AIM to brey1234
Smile state prison
This freq and pl are a common state prison system
Bob Reynolds-WB3DYE
Old 03-04-2013, 1:23 PM
markandjere's Avatar
For what its worth I SEEM to recall picking up that same frequency some time ago in that area , back when Chambersburg Boro PD used the same frequency. I thought maybe it was Bedford making its way through the mountains somehow .
REALISTIC PRO-53 , BEARCAT 145XL , BEARCAT 147XLT , RADIO SHACK PRO-46 , PRO-74 , PRO-2042 , PRO-2018 , PRO-96 (X 2)
Old 03-04-2013, 6:56 PM
I have this listed for the Pennsylvania Farm Show Complex. I last heard it in 2009. I do not get to Cumberland County as much as I used to.
Frank K3FS
http://www.pghscanner.com
Old 03-04-2013, 8:07 PM
k3cfc's Avatar
Originally Posted by captclint View Post
Not very helpful. Both are 100's of miles from Harrisburg. Since no one has entered the PL for this entry KA93574 (PENNSYLVANIA, COMMONWEALTH OF) FCC Callsign Details in the database, it is possible that is what you are hearing. Since there is another freq using that PL (Dauphin County, Pennsylvania (PA) Scanner Frequencies and Radio Frequency Reference) it is quite likely that this is it. If you determine that is it, by listening(Harrisburg Farm Show Complex), then please submit the PL to the database so others will be able to tell what it is by a search of the DB, which you could do if you were a member.
OP said 203.5
Don't confuse my personality with my attitude.
My personality is who I am.
My attitude depends on who you are.
Old 03-05-2013, 7:27 AM
benrussellpa's Avatar
Pennsylvania DB Admin
The Farm Show Complex was listed under the state database page. I discovered today, however, that another admin moved it to the Dauphin County page.
This is a Farm Show Complex repeater.
Old 03-05-2013, 7:57 AM
RonnieUSA's Avatar
The reason I answered with what I did was they have their location listed as Newport, PA, and I took it for granted that was where they were searching from.
So if You look at the map Bedford County is only 2 counties away.
If they are in Harrisburg then they should update their location.
Old 03-05-2013, 9:04 AM
Ronnie, I monitor from two locations...work and home. Newport is home...Harrisburg is work.
Dave
Old 03-05-2013, 9:30 AM
RonnieUSA's Avatar
Maybe I should read closer the next time.
Old 03-05-2013, 11:48 AM
No worries. I do that all the time.
Dave
Old 03-05-2013, 2:37 PM
captclint's Avatar
Mentor
Originally Posted by k3cfc View Post
OP said 203.5
Yes, but he had not confirmed that it is in fact the Farm Show at the time of my post. Certainly, that is the consensus so far.
Regards,
Clint Chamberlin
Luzerne County, PA
