Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > Pennsylvania Radio Discussion Forum
Pennsylvania Radio Discussion Forum - Forum for discussing Radio Information in the State of Pennsylvania.
  #21 (permalink)
Old 03-12-2014, 10:19 AM
lobo8000's Avatar
Default 39.4200?
Are the police and sheriff moving to UHF digital as well? Or are they remaining on 39.4200?
  #22 (permalink)
Old 03-12-2014, 2:01 PM
dmg1969's Avatar
From what they have been saying, it sounds like only some of the fireground channels are moving to the digital system. That seems odd, but....
Dave
My Scanners: HP-1, BC125AT, BC355N and Baofeng UV-5R2
Founder Perry County Pennsylvania Scanner Enthusiasts Group on Facebook
https://www.facebook.com/groups/407409399385884/
  #23 (permalink)
Old 03-12-2014, 8:03 PM
Think the list is getting out of whack
License WQNS272 is licensed as a trunking system. Base repeaters located at four
different locations. 453.2625, 453.5875, 460.1500, 460.3625, and 462.9500. (Ok in DB)
Permitted modes: 11K2F3E (Analog NFM), 8K10F1E (Digital p-25 phase-1) and 7K60FXE (Mototrbo)
License WQNC802 is licensed as a conventional system.
453.4125 Repeater (Ok)
453.5375 mobile (listed as B&M)
458.5375 mobile (listed as B&M)
460.5000 repeater (listed a B&M)
Permitted modes: 11K3F3E, 11K3F3E, 8K10F1E, and 7K60FXE
  #24 (permalink)
Old 03-18-2014, 6:32 AM
dmg1969's Avatar
My question is why the county is only switching 4 of their 7 fire OPS channels to a P25 system and not also migrating fire/EMS dispatch. Is if for interoperability with out of county units? Are there plans to eventually switch everything over to a P25 system?
Dave
  #25 (permalink)
Old 03-18-2014, 12:56 PM
Septa3371CSX1's Avatar
Most counties with volunteer fire/EMS agencies maintain analog dispatch frequencies for use by pagers. I don't know if anyone makes digital voice pagers but I imagine if so they would be rather expensive especially for a struggling volunteer fire department.
As for the other channels that are remaining analog there is a requirement (can't remember who requires it) that all fire radios have the ability to go to an analog simplex channel. Since analog simplex works best on a fireground that is likely why those frequencies are staying analog.
Joe Butler
Pro 95, Pro 97, Pro 106, Pro 651, Pro 668, & PSR 310 - Scanning the Delaware Valley!
Septa3371CSX1@aol.com
Victory5318@gmail.com
  #26 (permalink)
Old 03-18-2014, 1:37 PM
dmg1969's Avatar
OK, thanks for explaining that. That would make sense then why larger cities can have all channels on a digital system. Most firefighters and EMS are professionals and not volunteers.
Dave
  #27 (permalink)
Old 03-19-2014, 5:42 AM
SlipNutz15's Avatar
The reason the licenses were done how they were is because they could only get a limited number of frequencies because they band had not yet opened up other freqs because of the narrowbanding. The OPS channels are digital because the base transmitters are all digital and it requires an analog converter to operate in analog so they stayed with digital and the three channels they're using as analog are simplex not in county's radios.
The fireground channels have Talk-Around enabled across the board if a user cannot reach the tower, they can press a button on their portable or mobile and go to Direct mode for local operations.
The county is working on purchasing a few more frequencies for EMS operations and Law Enforcement.
The new system, according to the last words, is to be online and in use by the end of MARCH.
G. Stottle KB3THR
http://www.centralpascanner.com
  #28 (permalink)
Old 03-19-2014, 5:59 AM
dmg1969's Avatar
OK. Now another question. Will it operate as a regular P25 system with sites or are sites not required for this type of setup? I just checked the database and the new system is there, but only the NFM frequencies and Audio options (NAC or CTCSS). I myself am still very new to digital scanning.
Dave
  #29 (permalink)
Old 03-19-2014, 6:13 AM
SlipNutz15's Avatar
Dispatch will be simulcasted across all three towers.
OPS2 is P25 with NAC repeater at Tuscarora
OPS3 is P25 with NAC repeater at Shade (Richfield)
OPS4 is P25 with NAC repeater at Black Log
OPS5 is P25 with NAC repeater county-wide (not online yet)
OPS6-7-8 is analog with PL simplex non-county monitored
All information listed here:
Juniata County, Pennsylvania (PA) Scanner Frequencies and Radio Frequency Reference
G. Stottle KB3THR
  #30 (permalink)
Old 04-07-2014, 10:52 AM
lobo8000's Avatar
Default Analog Testing on 460.3625
I'm hearing fire chiefs from all over the county testing coverage on 460.3625 with PL 250.3 today. This is contrary to what the database says about that frequency being digital. Will this change?
  #31 (permalink)
Old 04-07-2014, 4:18 PM
SlipNutz15's Avatar
They are testing Ops5 in analog mode across all towers as a simulcast. Once they verify coverage and overlap issues they're reprogramming it as Dispatch and then Ops5 will go back to P25.
G. Stottle KB3THR
  #32 (permalink)
Old 04-08-2014, 2:39 PM
SlipNutz15's Avatar
As of today, 4/8/2014, dispatch is now simulcasted.
G. Stottle KB3THR
