CHESTER CO PROJECT 25
chankel
Ephrata, PA
Thanks for posting the presentation. From what I can see the site frequency assignements are still subject to change and it is going to be a while before any on-air testing starts.
mikemey
Landenberg, PA
I think I read the system won't even be online until 2015.
If it goes anything like the fire radio narrowbanding disaster then I wouldn't hold my breath on the timeline being met.
chankel
Ephrata, PA
Your prediction is probably correct, although it is possible they had a temporary site up and running for a few days to support demonstrations, but perhaps not. Even so I would tend to believe the frequency assignments are definitely not final.
DEPUTY11
what disaster was that?
W3AWF
Chester County, PA
As long as this Harris system is better than the current EFJunkson system, we'll be in good shape! I agree with you on the paging system, I'm lucky if it goes off when it's in my amplified charger which is connected to a dipole in my attic! It used to be the best sounding system in the area, now it's just pitiful.
mlmummert
If it makes you feel any better, I'm still able to receive the pages from York to Philly. Audio is lower though.
phillydjdan
Wirelessly posted (Mozilla/5.0 (Linux; U; Android 2.3.5; en-us; ZTE-N910 Build/GRJ90) AppleWebKit/533.1 (KHTML, like Gecko) Version/4.0 Mobile Safari/533.1)
I was traveling across the turnpike several years ago and was able to pickup dispatch as soon as i came out this side of the two tunnels using a vhf mobile. Thier signal strength always impressed me. i wonder just how bad it suffered now that its been narrowbanded.
jjimenez01
Royersford, PA
The county has spent a significant amount of time and resources to re-align the microwave signal from each of it's tower sites. I have noticed a marked improvement on the 160.185 and 159.600 frequencies. Occasionally there is low audio on field units on the East/Central rebroadcast.
JJ
ocguard
PA/MD
The pour audio quality and pager activation failures you'e experiencing in the county must have to do with simulcast multi-path or something, because I'm still copying 160.185 clearly (not as loud anymore) in York.
mikemey
Landenberg, PA
I know they've been working on the system, and I've noticed some improvement over the past week.
That said, I'd have my pager in the car at work, and not moving, and you'd hear the audio warble in and out on the pager, to the point where it would cut out (replay tells the truth). I could see that if I were moving, but stationary???
It may be the POS pagers they gave us. The Minitor 2's were great pagers, Why the Minitor 5's suck is beyond me. My Minitor 3 worked better than this thing.
cdavisjr
Conshohocken, PA
Anyone know if Chesters new system will be phase 1, 2 or both?...also is there any advantage to 2 vs 1 since it seems like more places are headed in that direction.
GTR8000
NY/NJ Database Guy
BEE00
Phase II (TDMA) systems are always capable of Phase I (FDMA) operation. The ability of a system to operate in TDMA (Phase II) mode depends on the physical hardware (infrastructure as well as radios) and the system programming on a per-talkgroup basis.
There is a significant advantage to Phase II TDMA, in that the voice channel capacity is doubled without having to add additional frequencies. With Phase I FDMA, a voice channel occupies the full bandwidth of a frequency. With Phase II TDMA, the voice channel is divided into two slots within a single frequency, so that a single frequency can handle voice traffic from two separate talkgroups simultaneously. A system that has 6 frequencies, for example, can only have 5 talkgroups active at the same time on a Phase I system (1 control channel + 5 voice channels), as opposed to 10 talkgroups active at the same time on a Phase II system (1 control channel + 10 voice channels/slots).
The article that was linked in the first post of this thread clearly states that it will be a Phase II system.
cdavisjr
Conshohocken, PA
I was unable repeatedly to get the link to open on my computer so to verbally ask was going to yield a quicker answer. On systems that are fully phase 2, does the technology still allow for vhf repeaters of the system or would they be a thing of the past also?
GTR8000
NY/NJ Database Guy
BEE00
Cross-links to other bands would be accomplished at either the console level (cross-patch) or at the hardware level (hardwire link). It doesn't matter whether the system uses FDMA or TDMA.
902
Downsouthsomewhere
The most efficient crosspatching would retain the data protocol and not break down into baseband audio. Going down to baseband audio would be the sum of all distortion in the pathway between the original system and the secondary system, but retaining the protocol, the audio between the systems should sound seamless.
