Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > Pennsylvania Radio Discussion Forum
Pennsylvania Radio Discussion Forum Forum for discussing Radio Information in the State of Pennsylvania.
Old 03-16-2013, 9:19 AM
wv_mountaineer's Avatar
Location: In a house along a busy road in Mercer County, Farrell, Pa.
Send a message via Yahoo to wv_mountaineer
Default Staley Communications - TRIConneX (WV-PA-OH)
I see a lot of info popping up for this system. It is a Mototrbo Connect Plus system. What do I have to do to monitor it? I would like to get in touch with the person or persons that is submitting the info and find out just what I need to do to get this endeavor started.
Scott in Mercer County Pa.
Uniden BCD-396XT & BCD-996XT, GRE PRS-300, Radio Shack Pro 164, Pro 97, Pro 51
My Mercer County, Pa. Live Feed: http://www.radioreference.com/apps/audio/?feedId=5084
Old 03-16-2013, 10:09 AM
mtindor's Avatar
OH/WV DB Admin
Send a message via MSN to mtindor
There's no "new" info popping up for this system. That information has been in the database for many months to over two years.
You need a discriminator-tapped receiver [or an SDR dongle] and Digital Speech Decoder (DSD). Look for Digital Speech Decoder in the wiki.
Mike / AA8IA
PSR800/PRO197
If you'd like to help me map out the First Energy P25 TRS, PM me
Old 03-16-2013, 10:53 AM
Is there anyone living around the Youngstown, Ohio area that would like to put a discriminator-tap into my 396XT? I'll come to you and pay the cost of the part and for your time. Just get back to me so we can set it up?
Old 03-16-2013, 11:05 AM
mtindor's Avatar
OH/WV DB Admin
Before you go that step, keep a few things in mind:
  1. Decoding TRBO / NXDN / P25 with your computer does require decent computer resources. Especially with TRBO, if you don't have a fast multicore hyperthreading CPU, you aren't going to get superior decode results. Audio will be very choppy during decode.
  2. It'll take time tweaking audio input settings on your computer and setting up your computer so that it works properly with DSD
  3. Depending upon your sound card, its sample rates, etc, you may or may not achieve the best decodes.
  4. There is very little that is automatic about decoding any of the modes that DSD decodes. It's a hands-on program.
  5. At any time down the road, any or all of the agencies / businesses you want to monitor could go encrypted and then you won't have anything to listen to on TRBO.
If you have a fast multicore hyperthreading machine, you might want to consider buying one of the cheap DVB-T dongles (do a search on the forums) and using one of those to attempt to decode TRBO to see if your heart is really in it. Of course, using one of the dongles and SDR software has a big learning curve all by itself.
Mike / AA8IA
PSR800/PRO197
Old 03-16-2013, 4:55 PM
Also I wouldnt recomend using a portable for a disc tap radio. There just not enough room in something like that. Would need a base scanner. Doesnt even need to be digital for this as the computer does the digital decoding.
Frank
Old 03-21-2013, 12:55 AM
I will tap your 996 if you want it done. I did mine and have used it to decode with no problem. I am in central Beaver County. Post your computer specs first though so we can see if it will likely run DSD or not.
