Copied from PRO96COM Group.
You can only monitor it in trunk mode on a pro-96/2096 due to the custom table setup it needs.
Ok, this configuration does have the ability to act like an EDACS system.
It seems like an odd way to set it up do me but that's what they did... This
limits the system to 16 channels, which for small systems like this one
isn't too bad.
In the Pro-96/2096, you would set up a table for each LCN, with the base
frequency being the frequency for that LCN.
This one would be something like this (assuming the LCNs go in frequency
order)...
Chlo Chhi Base Offset Step
0 4095 406.975 0 12.5
4096 8191 407.1375 4096 12.5
8192 12287 407.3875 8192 12.5
12288 16383 407.7875 12288 12.5
16384 20479 408.1750 16384 12.5
The step size isn't really important in this case, so I set it to 12.5khz...
For Pro96Com the identifier information would be:
0,406.9750,0.01250,10.00000
1,407.1375,0.01250,10.00000
2,407.3875,0.01250,10.00000
3,407.7875,0.01250,10.00000
4,408.1750,0.01250,10.00000
Unfortunately, I don't think Pro96Com reads this information from the tower
file (it should, and will in the future) so entering this information won't
help at the moment.
Frank N3OBL
FF/EMT
