Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > Pennsylvania Radio Discussion Forum
Pennsylvania Radio Discussion Forum - Forum for discussing Radio Information in the State of Pennsylvania.
Old 08-22-2014, 12:31 AM
rrbum's Avatar
Default Harrah's Chester casino gone digital
Harrah's Chester casino has begun using DMR. I have only just began collecting data. Seems the frequencies listed under FCC license WQFW556 are no longer analog voice. I do see at times both slots in use so I don't know if the information posted in the database as far as frequencies used exclusively by certain groups still applies. Does not appear to be a trunked system but rather a group of eight conventional freqs with different color codes for each as far as I have seen. I am by no means an expert on this type of thing and I do think that anyone in the area who would be interested in updating the database should monitor and collect info to submit. The activity is nonstop so it is a good example of a DMR system to study. I will begin to run dmrdecode this weekend to learn more but wanted to give a heads up to anyone within range who may be interested in something different to mes with and help provide good data to the database.
Old 08-22-2014, 12:37 AM
I will be taking my 436 to Vegas with me in about a month. I hope to hear many interesting things.
Old 08-23-2014, 12:12 PM
Steveradio's Avatar
everyone is going digital half the new frequencies see licensed.
http://lvcomm.proboards33.com/index.cgi
Scanning Lehigh Valley, Pa. North of Philadelphia
Old 08-23-2014, 2:18 PM
Unable to locate any license for digital operation. The list on RRDB is a little
out of kilter. There are two licenses. One conventional and one trunked. Both
are licensed for FMN (Analog) operation...
WQFH602 (Conventional)
463.2375 RM
463.5625 RM
463.9125 RM
WQFW556 (Trunked)
462.1375 RM
463.4375 RM
463.7125 RM
464.0125 RM
464.0375 RM
464.4375 RM
464.5875 RM
464.7875 RM
457.4125 M
467.2375 M
467.4125 M
Also checked applications for the last 365 days and nothing submitted
to change, add, or modify licenses...
The first license listed in the database (WQGT965) actually
belongs to the Pennsylvania Harness Racing Commission at the track.
This license is for a FMN analog repeater....
Old 08-23-2014, 3:13 PM
most likely Mototrbo or Nexedge, not the digital that your thinking of
Old 08-23-2014, 4:48 PM
Harrah's does not have a digital license for any system of any flavor... There are a
million other users in the Chester/Philadelphia area that do so perhaps the reception
is originating from another user.....
Old 08-23-2014, 5:07 PM
rrbum's Avatar
Be assured the digital transmissions I am monitoring are indeed from the Harrah's Chester casino. I listened to them as analog and the same banter on the same frequencies are now DMR. I hear them commenting on the new radios as they get used to them. The first thing I did was to check FCC emission data and found no indication of digital usage. Apparently people are switching to digital without notifying FCC all over the place as this is not the first case of digital transmission on an analog license I have seen.. I have been familiarizing myself with the system and see that so far only one frequency is encrypted. This seem not to be a trunked system.
Old 08-23-2014, 5:23 PM
ok. understand your comment. Will ask the van to have a listen at the end of
the month when their in the area... good luck
Old 08-23-2014, 5:34 PM
rrbum's Avatar
?????????????????????????????? Say what ?????????????????????????????????
Old 08-25-2014, 6:01 PM
Bout time. Having a casino on analog seemed stupid to me. They deal with a radio dealer for everything, so why they haven't submitted a license change is kinda baffling.
Old 08-31-2014, 1:07 PM
captaincab's Avatar
Location: monitoring delco pa with gre psr300 pro2053 and bearcat 560xlt
Probably has something to do with the dealer they use.
Old 09-02-2014, 8:41 PM
Well, since you brought it up....LOL
Old 09-02-2014, 9:30 PM
phillydjdan's Avatar
Ive also noticed this change. I have not had a chance to run DMR Decode on them yet, but did note that they hadnt changed thier licenses yet. I also noted several other licensees on other frequencies who have done the same. Im baffled as to how they get away with it. If it were me Id already have my fine mailed...
One step from "Banned For The Greater Good" lol
Old 09-03-2014, 3:48 AM
Had my 436HP with me in Vegas a couple of months ago. Worked great. Heard all kinds of stuff, including LVMPD P25. As you can see in the database, there are a multitude of trunking sites at the hotels and casinos. Was up on 15th floor of MonteCarlo with 436HP and RS-800 antenna, heard all sorts of stuff.
Bring a more suitable antenna for some of the VHF stuff and McCarran Airport. Have fun.
Steve AA6IO
Old 09-06-2014, 3:56 PM
So I've been running DMR Decode on several of Harrah's channels, and I think they may be using a Capacity Plus system. I'm seeing the Color Codes, Slots, & Groups. However, I'm noting the same Group numbers appearing on both slots on a given channel at different times. It appears they hop around from frequency and slot kind of like a P25 system. I've tried programming the channels into my XPR mobile, but even when DMR Decode is showing activity and the radio is showing activity, the speaker does not unmute. Some of the data does indicate a Capacity Plus system. Does this mean I am SOL or am I missing how to program a Capacity Plus system? Oh, and I should note that several of their frequencies are shared with Temple and St Joe's.
Old 09-06-2014, 9:07 PM
dtscho's Avatar
If they're using Capacity Plus, DMRDecode will output the words "Capacity Plus." Should be easy to spot.
As for why you're not picking it up on your XPR, the system may be using something called Restricted Access to System (RAS). It's not encryption, just a way of making sure that only authorized radios operate on the system. DMRDecode does not tell you whether the system is using RAS.
Encryption may be another reason you're not getting anything on the XPR. DMRDecode will show encryption being used. It will say "Privacy Enabled."
Dave
Old 09-06-2014, 9:34 PM
It clearly does say Capacity Plus. The question is does that mean nobody can program and monitor it, or are other factors at play (such as RAS or Privacy)?
The next question is: I guess you would need to "affiliate" in a way if RAS is enabled, correct?
I'm not seeing anything about privacy being enabled, at least.
Old 09-06-2014, 9:50 PM
dtscho's Avatar
Yes, if your XPR radio can handle a Capacity Plus system, then you should be able to monitor if programmed properly. If you're not seeing Privacy, the system is probably using RAS if you believe you have it programmed correctly.
Yes, RAS is a way for known radios to "affiliate" with the system. Radios that don't have RAS enabled will not unmute the speaker.
Dave
