Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > Pennsylvania Radio Discussion Forum
Pennsylvania Radio Discussion Forum Forum for discussing Radio Information in the State of Pennsylvania.
  #61 (permalink)
Old 09-22-2011, 5:28 PM
scan-pa's Avatar
RRDB Admin
Send a message via AIM to scan-pa
The new Consoles have been installed and are so much better. a few kinks are still left but there being worked on.
now everyone has a full dispatch console / work station.
Peter
Moderator: PhillyScanner Yahoo Group
Owner: http://www.scan-pa.com/
Webmaster: http://www.centralpafire.com/
  #62 (permalink)
Old 10-16-2011, 4:28 PM
scan-pa's Avatar
RRDB Admin
North System has added a LCN 6, anyone know the freq for North Site - LCN 6?
Peter
  #63 (permalink)
Old 10-16-2011, 9:32 PM
scan-pa's Avatar
RRDB Admin
NORTH
453.31250 * LCN1
453.71250 * LCN2
460.13750 * LCN3
460.26250 * LCN4
460.46250 * LCN5
453.07500 * LCN6 ** NEW **
DB has been updated.
Peter
  #64 (permalink)
Old 10-26-2011, 4:07 PM
scan-pa's Avatar
RRDB Admin
Now they are testing a new LCN for the South Site, LCN#8 is 453.3375, it is only being used in LCN test mode and is currently not availale to system users.
Peter
  #65 (permalink)
Old 11-11-2011, 7:58 AM
If I want to pick this up in the Ephrata area what site should I put in?
  #66 (permalink)
Old 11-17-2011, 9:32 PM
I believe the Lawn System is the one you want. It gets marginal reception in the Ephrata area. You can also try the Millcreek System since that's probably the closest to Ephrata but it doesn't carry much traffic except local traffic. The Lawn System doesn't carry everything either but it's not bad. You can't get the main systems from Ephrata.
  #67 (permalink)
Old 02-07-2012, 6:27 PM
jimsmowin's Avatar
can some one tell me what my settings should be on a 2096. i am having trouble getting it to recieve lebanon. it is used in a mobile while i am in lebanon co. thanks
pro 106; 2-pro 197's; pro 2096; pro 96; REGENCY ACT-E 10H/L/U SCANNING since 1975 WRIGHTSVILLE YORK CO. PA
  #68 (permalink)
Old 04-26-2012, 7:24 PM
Default edcas system
is there a certian order they have to be in when i program my scanner. Also i am having trouble programing a pro 2053 with the trucking but its the exact same way in my pro 164 as well as my bct15x I have all four site in all the scanners i am not sure if that good or not. The bct15x is always in my car and the pro 164 usually stays home or in myerstown. The pro 2053 picks up berks conventional just fine.
  #69 (permalink)
Old 06-12-2012, 6:15 PM
Is there something wrong with 460.1125 on the Lawn system? I was into Millcreek Twp in Lebanon county the other day and I was monitoring that system. And on two different radios the system was received beautifully except for that one frequency which wouldn't come in at all. How come? Is that the right frequency info in the db?
  #70 (permalink)
Old 01-27-2013, 8:12 AM
Default Lebanaon EDACS
I commute through Lebanon county daily on I-81 going to Harrisburg, I have a Uniden BCT15X scanner and have programmed the Lebanon system from the database here on radio reference with the FreeScan software but I have yet to hear anything from any sites on this system. I can pick up everything else so I know its not the radio or the antenna. I can pick up the FITG frequencies as well as mil-air over the gap almost to Hazleton. I have all 4 sites programmed in but I'm not sure what site/sites I should be able to receive along 1-81. Can anyone help? The latitude and longitude coordinates for all 4 sites are the same so I can't plot out the radius from the towers. Does anyone have updated coordinates?
Thanks,
Robert
