Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > Pennsylvania Radio Discussion Forum
Pennsylvania Radio Discussion Forum - Forum for discussing Radio Information in the State of Pennsylvania.
Old 11-02-2018, 8:10 PM
SlipNutz15's Avatar
Default ICORRS counties fire and ems dispatch
For those counties part of ICORRS, which counties are still using conventional paging for Fire and/or EMS services?
Armstrong - Fire was low band but shows deprecated. Are they using alpha pager or a different voice paging? EMS paging still 155.2200?
Fayette - Fire dispatch still 155.1900? EMS dispatch still 155.2950?
Indiana - Any Fire/EMS dispatch channels? Both showing deprecated. Alpha pager or another voice paging?
Lawrence - Fire/EMS paging still on 153.9950 or just fire? EMS paging shows 154.8000?
Somerset - Fire paging still lowband 33.7000? EMS paging still 155.1750?
Westmoreland - Fire paging still 154.0400? EMS still 155.1600?
Are any of these frequencies able to talk to county or just paging only?
Do any of these counties have PD patch frequencies?
G. Stottle KB3THR
http://www.centralpascanner.com
Old 11-02-2018, 8:15 PM
Fayette is using the two frequencies you mentioned. Indiana is exclusively alphanumeric paging on 900 MHz. Westmoreland is using the two channels you mentioned. Somerset is paging on just 155.175 MHz for fire and EMS now. I don't know exactly what Armstrong and Lawrence are utilizing. In Somerset, 155.175 is no longer monitored by dispatch for voice transmissions, I can't answer that question for the other counties.
Sent from my SM-G930V using Tapatalk
Craig Nicholson
Paramedic, 911 Telecommunicator
Somerset, PA
Somerset County 911
Old 11-02-2018, 8:16 PM
SlipNutz15's Avatar
Greatly appreciated, sir.
G. Stottle KB3THR
Old 11-02-2018, 11:32 PM
Armstrong and Indiana uses a uhf freq for EMS / FIRE pocsag paging.
Armstrong 460.1375
Indiana 460.2375
Old 11-02-2018, 11:34 PM
SlipNutz15's Avatar
Ok, so Armstrong and Indiana have no voice paging whatsover? Thank you, n3obl.
G. Stottle KB3THR
Old 11-03-2018, 1:02 PM
fire42man's Avatar
While Butler hasn't moved over to the system yet, they will continue using voice paging on 460.0625
PRO-163, BC72XLT, BC760XLT x3, Plectron R719 x2, Kenwood TH-78A, Cobra 19 Ultra III, Electra Bearcat IV
Old 11-03-2018, 1:20 PM
SlipNutz15's Avatar
I saw butler was tagged as a county on the system but didn’t see any TG info. Thank you.
G. Stottle KB3THR
Old 11-03-2018, 6:28 PM
Butler county is in the process of moving off their current uhf, 470 NHS system. They will be going 800 mhz p25. They are moving off 470 due to the T-band take back from the FCC. Not sure when the system will be on line.
Old 11-05-2018, 8:15 PM
SlipNutz15's Avatar
Thank you. Do any of these counties have an out-of-county contact channel such as VLAW or UCALL or Med 4?
G. Stottle KB3THR
Old 11-06-2018, 1:39 AM
ICORRS System Wide Talk Groups And Simplex Talk Around
Sent from my Moto Z (2) using Tapatalk
Old 11-06-2018, 2:41 AM
yes all ICORRS radios are supposed to get programmed with the IC wide area talk groups now there are so many radios in service prior to adding those talk groups that many are missing those.
The 800 t/a channels are the same for every county. Which coincidentally they are the 800 nat interop channels in direct mode with no PL tone.
Old 11-06-2018, 3:17 AM
SlipNutz15's Avatar
Does county have access to these or are they just mobile off system frequencies?
G. Stottle KB3THR
Old 11-06-2018, 4:37 AM
Fire 16 I Believe Not Can't Recall On EMS, Pd. That's Why The Tell You To Monitor Your CDM Channel In Westmoreland.
Old 11-06-2018, 7:30 PM
Rumor has it, that when they do switch over, the PD channels are going to be encrypted.
Tags
ems, fire, iccors, pager, paging
