Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > Pennsylvania Radio Discussion Forum
Pennsylvania Radio Discussion Forum - Forum for discussing Radio Information in the State of Pennsylvania.
Old 09-17-2006, 11:41 PM
Default Geisinger Life Flight Radio Codes
Working at the 911 center I have heard Geisinger talking to field units and then back to Geisinger primarily on the UHF-MED Frequencies. I have recently heard them state that a patient is "Code 5" and that's all I heard then. Are these Codes the patient classification codes in START Triage (i.e. Code 1 is Critical, Code 2 Stable Code 3 Minor Code 4 DOA)? If so, what would a 5 be? Just curious as to see if anyone knows. Thanks in advance for any assistance.
Old 09-18-2006, 11:47 AM
Default Code 5 = Class 5?
Probably the code 5 designator means class 5 which in most areas is the DOA. I think class 4 is rarely used and may mean that the patient has no issues and so EMS is a Taxi.
N3JYD
Old 09-18-2006, 3:09 PM
ctrabs74's Avatar
This is what Philadelphia, Bucks County, and Montgomery County uses to classify patients (which, I'm presuming, is the same as what Geisinger uses):
Class 1 - High Priority/Critical
Class 2 - Medium Priority
Class 3 - Low Priority/Routine
Class 4 - Psychiatric Patient (Class 4X - Violent Psych Patient)
Class 5 - DOA
(Side note: MontCo 329 - Goodwill Ambulance/Pottstown - uses the above system even when responding on Chester County radio, most likely out of force of habit.)
Creighton Rabs
California, Pa. (Washington County)
