Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > Pennsylvania Radio Discussion Forum
Pennsylvania Radio Discussion Forum Forum for discussing Radio Information in the State of Pennsylvania.
  #361 (permalink)
Old 07-14-2012, 7:16 AM
Originally Posted by skirvy22 View Post
so the following would be correct? extended tables: #00 CH LO 0, CH HI 65535, Base 500.00, Offset 0, Step 12.5
Correct. As someone else mentioned, make sure you enter all system frequencies, as an frequency can be the control channel.
Matt
"If the tallest building in your county is a grain silo, you DON'T need 800mhz!"
  #362 (permalink)
Old 07-14-2012, 8:27 AM
cool. thanks for everyones help.
  #363 (permalink)
Old 10-01-2012, 3:57 PM
Default air talk groups
A recent message from York County 911 has informed users that two new talk groups have been added for communication with aeromedical services when responding to York County. They are titles YC_AIR1 and YC_AIR2.
Despite the message referring to them as talk groups, I suspect they may be conventional channels, since it mentioned that subscriber radios won't have them -- they'll have to be patched to the Ops talk group. Also, as far as I know, the two air ambulance services that come to York County regularly have radios that can operate in P25 conventional mode only, not trunking capable.
Matt
  #364 (permalink)
Old 10-02-2012, 8:24 AM
dcr_inc's Avatar
Thumbs up
Confirmed:
YC_air1 and 2 are TRUNKED talk groups..
Splat and Life Lion both have P25 modules on board and are programmed with the YC_air 1 and 2 talk groups..
A patch will be used to bring them on line until a reprogramming is done sometime in the future
  #365 (permalink)
Old 10-03-2012, 8:56 AM
dcr_inc's Avatar
12184 YC_AIR 1
12185 YC_AIR 2
Talkgroup ID's
  #366 (permalink)
Old 10-03-2012, 1:24 PM
markandjere's Avatar
Never heard of Splat .....could you post a some info?
REALISTIC PRO-53 , BEARCAT 145XL , BEARCAT 147XLT , RADIO SHACK PRO-46 , PRO-74 , PRO-2042 , PRO-2018 , PRO-96 (X 2)
  #367 (permalink)
Old 10-04-2012, 7:16 PM
dcr_inc's Avatar
Unhappy
Stat Medevac
  #368 (permalink)
Old 10-04-2012, 7:57 PM
Ok......
  #369 (permalink)
Old 10-04-2012, 8:40 PM
tglendye's Avatar
Originally Posted by dcr_inc View Post
Stat Medevac
Might have problems w/ one named "Splat"
Todd
PSR-500, PSR-410, Pro-197, BC780xlt and lots of older stuff.
  #370 (permalink)
Old 10-06-2012, 1:15 PM
dcr_inc's Avatar
Unhappy
It's better than Life Lion being called "Death Kitty"...
  #371 (permalink)
Old 11-25-2012, 1:23 AM
Quick question: I run with a company in chester county, but am often driving through York County and will be working there soon. I have a radio shack PRO-25 direct entry scanner with hyperscan. I have delaware county 500 mhz frequencies programmed. I recently programmed all of York's new 500 mhz frequencies for west, south, central and fulton. When I am in York, I get a lot of clicking as would get from MDT transmission and no voice from remaining few frequencies not locked out. Anyone know of anything that might help?
  #372 (permalink)
Old 11-25-2012, 12:40 PM
hosehead88's Avatar
York is a digital system and the Pro-25 is not a digital scanner. You will not be able to monitor the system.
FTM-PTB-EGH
West Shore Bureau of Fire
996XT/PSR-600(x2)/PSR-500/Pro-2096/Pro-2055/Pro-97/Pro-2026/Pro-2036
  #373 (permalink)
Old 11-25-2012, 12:50 PM
Hosehead88: thanks. So the clicks are just data transmissions then. I assumed that because Delaware County was using a 500 mgz system and Chester County was using trunked 800 mhz and I could hear them well that I would be able to pick up York. I need to get a new hand held scanner trunk, hyperscan, digital and analog at least 200 channel and INEXPENSIVE. Any suggestions? Thanks.
  #374 (permalink)
Old 11-26-2012, 12:59 PM
hosehead88's Avatar
Unfortunately there is no such thing as a digital trunking scanner that is inexpensive.
Sent from my Galaxy Nexus using Tapatalk 2
FTM-PTB-EGH
  #375 (permalink)
Old 11-26-2012, 4:44 PM
You could always try buying used . I bought both my Pro-96's used for about $200.00 each. Try looking on eBAY or even Pawn Shops in Md. I picked mine up in Hagerstown. Just use good judgement if you go the eBAY route .
  #376 (permalink)
Old 11-27-2012, 9:56 PM
I'm fairly certain that Chester County is soon switching to a digital system as well. Your investment in a digital scanner may be increased.
Matt
  #377 (permalink)
Old 11-27-2012, 11:08 PM
benrussellpa's Avatar
Pennsylvania DB Admin
Yes, Chester County will be going P25 digital. An RFP was put out earlier this year or late last year for the system, but I have not seen anything officially awarded, yet.
  #378 (permalink)
Old 12-06-2012, 6:39 PM
Pretty active with Chester County and have not heard anything. Invested too much in current system - commissioners are not putting any more money into new systems or drastic system changes.
  #379 (permalink)
Old 12-09-2012, 9:51 AM
question...i just bought the pro 106 and uploaded york county pa and havent heard anything. I programmed it with win500. I had the same issue with my p96 radio and had to adjust the tables. Do i need to do the same with this radio? thanks.
  #380 (permalink)
Old 12-09-2012, 6:42 PM
As I mentioned earlier, an RFP was already released for a new Chester County radio system. I don't know who got the award in 2012 (never saw it announced). I'll ask around to find out the status of the project, but there is a project in the works for a major upgrade to the Chester County system to make it a P25 compliant digital trunked system.
